My ceFIRO
weikee
924
15
2L for more power, or 2.5L box for more fuel economical. But all this got to match with the torque curve
sb3
1,141
14
5,138
VQ23DE ? u r driving a teana? Why so fast kong g/box? I've never seen any yet at chop shop.
RandyC
49
4
1,508
oh, this car brought in from SG long ago. Its the pre-facelift model, the one without the Projector Headlamp ^^
Well there is this very loud and wierd growling sound coming from the engine bay when i rev the engine up (the sound comes and go smth like grorrroarrr .. quiet... ggrrrooarr... quiet .. )
i dont know where is it coming from so imjust preparing myself for the worst lor. That time a shop in melaka used his scanner to scan for error codes and says one of my knock sensor faulty. Wonder if that could be the cause?
hmmm...
weikee
924
15
just make sure you use original nissan ATF oil. Nissan auto box need to use original nissan ATF oils, else you risk killing the box.
Worse you can ask some chopshop to cut you one 1/2 cut from Japan.
RandyC
49
4
1,508
how much will the original Nissan ATF cost ar if i were to go out and change atf ?
XTEC
873
219
1,543
bro ur gear box using normal ATF oil or CVVT oil? pls double comfirn ler. later kong
RandyC
49
4
1,508
dint know there is such a thing too. i took over this car not too long ago, no idea of its history, thts y i need advise on a good place to check on the car, price to flush n change d atf ... :s
XTEC
873
219
1,543
bro check for u liao, if yours are 230jm then is CVVT gear box.
change ATF with CVVT & dont ever use ATF type D comfirn ur gearbox kong.
weikee
924
15
check the engine code, and best to send the car to TCM for first time service. If your car is confirm CVT box, and you use normal ATF oil. is time to saved money for a g.box. and you may need to wait 3 to 6 months to find a used g.box cause the chop shop here don't keep stock.
Think not expensive lah, last my friend sold a used honda citi cvt box, is only 8k
---------- Post added at 11:05 AM ---------- 6 hour anti-bump limit - Previous post was at 10:58 AM ----------
BTW, CVT also have 2 type of oil, so you need to check the g.box code to confirm. check the plate on your engine bay.
gsrturbo86
59
thanks so much guys for these info. Any rough idea how much would it cost to send my car to TCM to service my g.box as in change the fluid ?
sb3
1,141
14
5,138
i tried injector clean recently... found fc become better after 2nd tong of petrol
injector dirty?
Sure or not, I ve used injector cleaner b4, no difference wan? Wat brand u use?
:biggrin:
The Marketplace Top Posts
LOS ANGELES (Hollywood Reporter) - Rev those engines! Vin Diesel and Paul Walker are in negotiations to reunite for the fourth installment of the "Fast and the Furious" action franchise.
The story line of Universal's as-yet-untitled installment is being kept under wraps, but fast cars are involved. A spring start is anticipated with shooting in Los Angeles, Mexico and the Dominican Republic.
The first "Furious," released in 2001...
