A car without LSD has a non LSD "differential" inside your gearbox. When u found an lsd that is suitable for your gearbox, u simply replace the original differential with the lsd (limited slip differential). No mods required and u can't mod an lsd to suit gearboxes.
eater,
b16a original lsd, when u jack up the car and turn one side of the wheel, the other side will turn in the same direction. For type r original lsd, when u turn one side, the other side will not turn. It uses a different system. One sure way to know whether u hv lsd or not, take out wheels and drive shafts, and try to look through the gear box from side ways. If you can see through the drive shaft, u've got lsd. If not, u ain't got lsd. I'm now running on type r lsd. It doesn't have the full lock features found in a full lock lsd. My driving impression : it works while launching the car, and helps slightly on corners. I've tried a full lock lsd before, and it's totally different from the std b16a or type r lsd's. Cut the long story short; good. But gotta live with the clanking sound at junction type of corners.
