looking spare parts?
AccordRacing
2,282
kepong
www.zhapalang.com.my
many new thing add on
just drop ur msg or pm me,i will reply as soon as possible,normally KL area
10s :P
normally those car model which exist in our country,not import model,wat i have:
1)engine parts-engine overhauled set,water pump,engine mounting,timing belt kits
2)suspension parts-absober(monroe,gabriel,kyb,apm,tokico etc),rubber mounting,rubber bush,lower arm,tie rod end,rack end,ball joint etc
3)cooling system-water hose,radiator fan motor,a/c motor,switch,radiator
4)maintaince parts-lubricant(shell,catrol,petronas,mobil,chemlube etc),spark plug(bosch super4,ngk laser platinum,ngk g-power,iritium,champion plug),air filter,oil filter,fuel filter,oil treatment,gear oil etc
5)transmission parts-cluctch kits
6)bodyparts-mudguard,wind screen,panel,moulding etc
7)braking system-disc rotor,brake hose,brake master pump,brake pump,wheel pump,caliber repair kits,brake pad(mintye,bendix metal king,ferodo racing,lucas trw,don,mintex,sumitomo)
8)accesories parts-latest toyota,honda fog light come wif bracket full wiring(vios,altis,camry,accord,civic,city,civic99,crv etc),angel eye spotlight(7 color without white),aluminium lock nut,HID kits,stylish head lamp/tail lamp,spoiler abs(accord,city,crv,x-trail,vios,altis etc),aluminium spoiler
special add on:
suspension-brand available panther.rg sport,koni,hot bits,sachs,hwl,gab,eibach spring,tanabe japan,arh absober,pu bushing
others-blow off valve,turbo timer(special feature got tachometer,can set a specific rpm n sound came out),meter ,k&n a/filter etc
if interested kindly contact 012-2363293/016-3282268 for more information,location nearby jusco kepong,cc acceptable,msn contact [email protected], website : http://zhapalang.com.my
Partnering Sellers/Merchants:
>> c-ground
>> HMS
>> Rock Lee
AccordRacing
2,282
kepong
:ph34r: if u wan instant reply the stuff price tat u require?sms me at mon~sat,working period 9am~6pm.
012-2363293 no joker aorund
SKY999
490
kch
looking for st185 or st205 door panel.oe mr2 sw20 door panel,u got ? pm me the price.
xin
626
looking for CyborgZR front bumper ..the small cover that use to cover up the tow hook...thanks
infinity79
bump!!
looking for mazda 323 BF 1989/90 signal cover.....half-cut or OEM....
if u manage to get those part , PM or sms me on 019 374 5046 bout da price or anything...
thx man
-infinity79-
AccordRacing
2,282
kepong
this 1 not original spec,sorry don have
AccordRacing
2,282
kepong
wat color is it?white or black,fuel&temp,rpm or meter n gear?pls note clear
AccordRacing
2,282
kepong
satria on top roof driver side rubber type plastic
that 1 only have original,its cost rm190 for driver side,10s 4 ur request
Hi, I am currently looking for a new setup of adjustables. I am very convinced with the D2. Where the adjustable options are more. 2 different location of adjustables. The spring height and the mount height. And also soft hard. Price is not very expensive. And very solid built and look nice too.
I would like to know if there is anyone here every tried D2. I believe it's from Taiwan. Correct me if i am wrong.
I am actually looking for something like TEIN. Comfort yet good performance in...
