Hi bro,
Anyone can help me to find some half cuts, engines & parts as below, and the price..
1. Evo 7 - 10 (either 1) half cut
2. Honda Accord (93-97) Auto transmission (half cut version)
3. Toyota 4A-GZE supercharger half cut live engine.
4. Srewed type Supercharger assembly (not working also can)
5. G ladder type Supercharger assembly (not working also can)
6. Toyota 4A-FE (shim type valve) live engine
7. Proton S4ph live engine
8. Honda Prelude (H22A)
- valve cover gasket
- valve cover bush
- map sensor
- T.P.S sensor
- main fused - 40AM(2), 50AM (1)
- Raiator cap
9. Nissan Twin Cam 16V (GAL6)
- Fuel pump
- Temp. sensor
10. BMW 316i (WBACG 120)
- Intake magnifold inlet hose (original)
- Radiator fan sensor
- Accelerator cable and pedal spring
- Air-flow meter assy
- high tension wire assy
- head light assy (righthand side)
- Clutch kit assy (clutch disc, pressure plate, release bearing)
- Wiper blade
- Hood lifter (damper)
- Door moulding (rh side)
- Brake shoe lock and spring (RR)
- combination switch assy (steering)
- Side mirror (LHside) mirror only
- fuel pump - Denso 195160/0740
- valve cover screw (10) / bush (15)
- air flow sensor
11. Gen 2
- clutch pedal assembly
- clutch master cylinder
- clutch fluid line
- sleeve cylinder
- manual transaxle assembly
- clutch fork
- release bearing
- clutch disc
- pressure plate and clutch cover assembly
12. CAMPRO
- cylinder block
- flywheel
- crankshaft
- crankshaft main bearing cap
- crankshaft bolt
All this is for college training purpose.
Thank you very much.
- valve cover bush
- map sensor
- T.P.S sensor
- Raiator cap
- Fuel pump
- Temp. sensor
- Wiper blade
- air flow sensor
11. Gen 2
- clutch fluid line
- sleeve cylinder
- clutch fork
- release bearing
- clutch disc
12. CAMPRO
- cylinder block
- flywheel
- crankshaft
- crankshaft bolt
