LED for Eagle Eye
babysmile
25
yippie... faster post da pic .... b4 u really selling the car?? do the angel eyes already and now wan to sell car?? really bo??
C
chilskater
Guest
just now i saw EK with eagle eyes...close view show that small circuit of mini LED attached to the rod...the is like hset LED but super bright...if someone can create small circuit board with mini Led on it...sure can do it...
PenangJin1984
97
@_@
boss .. when u saw this message send sms for me ...
my led Sot 1 side =.= so sad... keep flash ..
ya wan sell lo.. change civic i think
if i work sui sui .. den change civic 2.0
i just back from kl
ccfl 4 only rm2xx =.= so cheap
babysmile
25
Received your message... how about I check for u at nite or make it saturday??
Mostly u get flashing because u didn't solder it well...
but not to worry. should be easily done...
PenangJin1984
97
hmm.. nite ? when @@? me everyday free..
haha but i need to start working hard lo @@"
i think going kl or where ..
if can la .. haha in pg already sien .. =/
somemore salary all low low 1...
i wan get higher salary to change my fetutre car ..
johnkor
69
7
1,508
bro after i saw your post , this is so Kick ARSE man ! Salute you , more upgrades mate hehe!
idnawse
205
36
perak
want to share my DIY (currently done 1 side only)
CCFL ring inside iswara headlamp+A31 projector and yellow lamp
not so nice coz iswara headlamp got so many lines on it.. :banghead:
ken yeang
6,000 RPM
6,617
1,327
nice job there. just a little curious, will prolong heat from the head lamp effect the plastic eagle eyes?
mivecmerah
799
who knows dying ccfl eh?how about using computer fan ccfl?any solution?
idnawse
205
36
perak
should be no prob if using that ccfl but must remember, even pc using 12v (DC), but check the current (Amp) first. if not, the inverter easily blown.. fm my experience
idnawse
205
36
perak
step 1. open the headlamp
LED ring and inside cover
ring area (closed up)
before spray (with flat black)
after spray
put small screw (hold the ring casing)
put ring inside the casing
testinggg....... (normal camera exposure - too bright)
set the exposure to low
put back all the clips
done... stage 1
step 2...
fix the headlamp and re-wiring
photosession :lol:
closed up
the ring is too bright...
best shoot with low exposure setting
The Marketplace Top Posts
Dear guys,
Need some of your feedback although i've read similar threads discussion the same issue.
The issue is my water temp currently shows temp running abit high during cruising, speeding and boosting.
On traffic jams, temp will remain at 90-95c
Cruising on highway, temp will raise up till 100c
Boosting at 0.8 bar will raise up to 110c
Here are the some tech specs of my car
-4EFTE engine
-D&D (4 core aluminium) civic eg radiator
-Removed thermostat
-Toyota...
