L2 and L5 Boost Cut Modification
E-Tech
1,115
256
3,183
Johor
Hi guys....
I have made a thread regrading this subject in Perodua section.
Pls see my posting if you need it... FOC.
I know there are many kancils with L2 and L5 out there... this DIY will surely help you beat
a standard L2 or L5.... percaya lah.... hanya Rm0.50 and usaha anda sendiri..
Buy the way.... if you can get hold of cheap 5 Button Apexi SAFC it will be even better...
Market price for 5 button ranges from RM350- RM450...
For this modification must know what is ECU, screw driver, soldering iron, solder wire.
Just providing information service... if want to contribute $$$, it;s up to you. TQ
l200turbo
88
another way is with 1 way valve install before sensor.fewbucks oni , just cut n put in between the hose,no need to disturb the comp box.
l200turbo
88
if below 1 bar still ok.if more than that recommend u retune ur air fuel ratio.
E-Tech
1,115
256
3,183
Johor
how to tune??using fuel presure regulator???
Bro if your always go more than 1 bar....then here a some solution to up the a/f ratio...
1. Adjustable fuel regulator- 4/10
2. SAFC - 6/10
3. Bigger injector + SAFC - 9/10
Tq
monster111
61
3,008
2. SAFC - 6/10
Tq
there is another crude way to fool some "stupid" ecu like L2
by using a 3-pin 10k rheostat or variable resistor, cut the signal wire from ecu to map sensor and connect it the middle pin of rheostat. then the left pin to GND (to reduce fuel) or +5V (to add fuel). the right pin of rheostat to map sensor.
will post the diagram tonite:biggrin:
FortisCuore
23
I want to install a 5 button AFC on my L2 turbo computer. What colour wires do I tap into?
msharif
Sep 23, 2011
6
JOHORE
hi i m new member here,is it emanage more batter than afc 5 button,coz i plan to install emanage to my car very soon.....
---------- Post added at 04:16 PM ---------- 6 hour anti-bump limit - Previous post was at 04:09 PM ----------
to our otai here...what is the max piston can rebore to my 850 block..currently i used 68mm L2 carburator turbo piston...sommore..if anyone
hve TDO5 subaru twin blade turbo to sell...currently i used TDO5 pajero diesel for my L2S...
turbo^san
Dec 2, 2011
13
Selangor
bro..which pajero using TD05..? i think pajero only using TD04...correct me if i wrong..thanx..
Hi all, I hv a problem after a high boost on my 4G93 Turbo when i slow down the car, suddenly my engine went died. Hav to restart immediately to bring back my power stering. Very dangerous. Happened few times. plz help. Will tis affect my engine if it died and i restart immediately? plz help. Thks.
