Is there a problem?
fookongmick
12
I am driving a Daihatsu Charade G100 1L carburetor.
Here's the problem:
1. When I on my car's headlamps, my idle drops about 200rpm.
2. When my radiator fan cuts in I loose about 100rpm.
So i have to like tune my car up 1200rpm to make sure the rpm doesn't fall too law and the car won't shake too much.
What could be the problem?
[s]UpErNoVa
313
hmm.. i guess tat's a normal scenario bro.. since ur car is considered kinda old ( i guess got 10 years old :regular_smile: ).. cheers! :regular_smile:
fookongmick
12
I have plenty of grounding for my car... 5 ground cables...
Would changing the alternator make a difference?
gloss
1,546
SJ
5 points is just the basic, most vital is the grounding points.
your voltage is not stable. if you hv a volt meter better, to check
volt reading..
find huakenny in zth for more details on volt stablizer.
Fluffy
3,870
>>klang<<
yup.get VS frm him.
erm..the alternator if u really dont have enuf voltage running thru ur car.but just get the two items mentioned 1st.IMO.
DewA ArjunA
37
Go and try to check ur wiring.Try cleaning ur terminal as well as the negative earth wire which connected from the negative terminal to the body of your car.Mayb theres rust there.If everything is ok then go for VS and/or grounding wires.
vantageX
103
The 100rpm drop after the fan comes on sounds about right if not slightly high but acceptable.
The 200rpm drop after the headlamps come on however doesn't sound right. Do the above tips, clean your battery terminals, check the main fuse, check the headlamp grounding. Clean all these things and you should notice a slight difference if not a total cure.
But if its only a slight difference or no difference at all then I think its time you take a look at your alternator. Have you changed it before? If so is it the correct Amperage type? Any competant car electrician should be able to check it.
About the voltage stabilizer, some cars have an external one while most alternators these days come with a built in voltage stabilizer. If your car has an external one, don't rule it out. Get the electrician to check it and make sure the alternator is working properly and the external stabilizer is also doing its job.
Good luck!
fookongmick
12
Thanks for the tips... Will try it out and get back to you....
kyheng
1,202
seremban
Worst case, change car wiring, alternator(if never change before). Do you have heavy ICE inside your car? I don't think VS can help much on this, if the alternator have problem already. The car built for the past 10 years is standard and capable to run all the eletric components in your car. So after 10 years, if you only change battery(every 2 years or more), then your problem is the alternator or wiring need to change. This is on the eletrical part. the easiest way is get a volt meter and measure. If the car is not started, voltage should be +-12V, if started, it should have 13.4-13.9v.
For engine part, if you never change the mountings before, then maybe that's another cause. For a standard car, the rpm on idle should be around 800-1000, if set the timing higher, then you will waste more petrol.
fookongmick
12
Checked the voltage. It is giving a healthy reading. 12V car off, 13.4 -13.9 when engine on.
Could it be the HT coil?
TiBuN
482
Penang / BM
It's time to visit your local half cut shop :_:
Anyway, does it kill your engine if everything is turned ON ?
Or will the dashboard 'rattle' due to the low RPM only ?
If it doesn't kill your car, don't fix it.
vantageX
103
If its the HT coil you'll be seeing some other problems as well.
13.4-13.9V is ok though it could be slightly higher. Did you test it with your air-cond and headlights on or off?
<a href="http://www.zerotohundred.com/newforums/features/159850-girls-of-afos-malaysian-series-2007-sepang-circuit.html"><img border="0" src="http://www.zerotohundred.com/features/may/afos_malaysia_2007/girls/banner.jpg" width="250" height="75"></a><p><b>Girls of AFOS - Malaysian Series 2007 Sepang Circuit</b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><p><b>Images: </b>Andy...
