integra type R b18c 4-1 2000 spec manifold
coolblue
293
integra type R b18c 4-1 exhaust manifold
stock from type R ,
with O2 sensor and donut ,
$750 net ,
pm me if intrested ,
can arrange to view them at setapak / sunway
thank you
mizie
43
selayang
pls call me...serious buyer here...urgent!!!!0193945373...mizie...thanksss
mizie
43
selayang
exhaust manifold..
stock from type R ,
$750 net ,
thank you
halloo encik...mau juai ka tak mau...apa pasat tak mau call sama sya...sya mau itu barang...
plsss call me ok...urgent....0193945373...mizie
coolblue
293
kalau tak boleh tunggu .. lain tempat pun ada jual ,
saya bukan di depan komputer 24jam tunngu kamu punya msg ,
saya punya tel 019 230 9162
aramis
678
Cyberjaya/KL/PJ
www.scuba2u.com
not need to modify. Just Plug and Play, but you have to be careful when going over bumps coz the header will hit them if you are not careful... ;)
coolblue
293
if your civic lower untill very low , then have to slow on speed bumps ,
because the 4-1 pipes under the oil pan are quite low on civic's .
aramis
678
Cyberjaya/KL/PJ
www.scuba2u.com
i dont think the pipes are low, B16A block have different height as compare to B18C.
correct me if Im wrong..
coolblue
293
well the 4-1 has two extra pipe compare to the regular 421 type ,
as i can see they are 3/4 lenght of the pipe higher then then stock b16a units ,
that will be the same as on the mugens 4-1 as well ,
Hi guys,
How many of you that own Protons, namely Satrias or Satria GTIs have had to change your wheel bearings before?
I am currently experience symptoms of worn out wheel bearings but whenever i send it to the shop there are no problems probably because the bearings haven't been heated up to where they start to display problems that i've been experiencing.
Problems:
Steering wheel judders when turning left on hard cornering.
Feels like the right front wheel is slightly loose...
