Howdy fellows. I've had this problem before and i tried everyting including getting the original 99 spec mounting hardware from Japan with no luck. There are couple of areas you should look at:
1. Drain from sunroof. It has 4 drains on each side. They can sometimes be clogged up with leafs of debris. so check this first.
2. Rubber connectors sometimes leave a gap enough to let water in so check them too.
3. Check your wing mounts.
And finally i found my problem at least.
I used sealant (transparent type) and let it dry for about 15 minutes before installing again. So far so good. its been 3 months.
So good luck with your quest.
This nylon bush is usually missing or screwed.
Location of where i added plenty of sealant and secured afterwards.
Goodluck
Dev
Goodluck
Dev
