How to read Air Fuel Ratio Meter?
evo3
1,794
24
Hi,
Need help on reading A/F Ration...hehehe...
Yesterday i install a A/F Ration meter, and it doesn't show any reading when idling..no light indicator but when the car is moving and u release the gas pedal then it will onlt show the reading...it tat ok or that is something wrong? :P
Thanks
CcL
506
5,018
ehhhhh
as long as the O2 sensor is warmed up there should be a reading
even when the engine is off!!
check the wirings...
evo3
1,794
24
i have check the wiring....it is ok...cos only one wire to the O2 sensor.....is the wire that i use not suitable cos i using the Red/Black wire...but i use one piece only la....hehehe
DRFT_240sx
890
22
5,018
well i assume u are using a narrow band O2 sensor , when during idling open loop it should be bouncing up and down...
when driving/cruising in close loop then u will have indication of where your a/f ratio is ( this is during WOT).
no point to invest in a narrowband , just for display only.... the one that actually indicates if you are running rich/lean is wideband O2 sensors.
cheers
cmng
3,289
72
narrow band is better then nothing
at least you get some figure
Wideband.
only rich boy will drive and use wideband AFR meter all the time
acbc
4,615
KD
Yeah... feel like removing my AutoMeter A/F Meter and put it up for sale soon...
evo3
1,794
24
hehehe..wide band too expensive...i install it for the reading when the boost start to kick in.....hehehe
Yeah...when idle , it should bounce up and down but this a/f meter, show no reading....it only show reading when i release the gas pedal or when the boost start to kick in...hehe...
Oh yeah..i tap the signal from the sensor at the exhaust manifold.....or i should tap the signaL from the ECU? :P :D
alvin24
3,109
27
Actually first thing is you should mention what brand airfuel ratio u've installed.
If its autometer... during idling it shold be bouncing up and down. During acceleration it should be reading rich.... and deceleration it should go down to red... if u're maintaining speed, it should be bouncing up and down as well... (assuming healthy fueling conditions).
Maybe other brands got other readings? Hahaa...
If its always on red... means either your O2 sensor kong... or the wiring got problem.
You'll need to warm up the O2 sensor first before u start getting readings.. else its always on red also.
DRFT_240sx
890
22
5,018
the warm up part i should say would only apply to a 3/4 wire O2 sensor... not those with single wire O2 sensor....
I would say no matter where you tap , close loop ( WOT) show your real reading , either in rich , lean or stoich , open loop then it is suppose to bounce up and down when u are not in WOT.....
cheers
evo3
1,794
24
oic....thxs
ezwong2002
452
Butterworth, Penang
www.geocities.com
ok.. that is the easy part to read A/F ratio via Autometer type gauge.. what about Apexi T/Timer A/F ratio? 14.6 <--- stoich, lean or rich? what i know is.. green (lean) red (rich) yellow (stoich) and how to set la the bloody thing? sighh...
Joeker
Walking Dead
3,580
62
Jinjang
The brand or make of the A/F meter or gauge is irregardless.
Wat realy matters is the 02 sensor.
A narrow band 02 sensor oni reads stoich/near stoich (0.1~1V).
A wide band 02 sensor reads a broader band (eg. 0.01 ~ 2V). It will be able to show how much rich or mch much lean u are actually at.
My fren had his APEXi TT cum A/F meter benchmarked side-by-side with a MOTEC wide band A/D meter.
The result was APEXi was totally hopeless.
Therefore, to all u guys who "tune" your own cars with the aftermarket A/F meters using stock narrow band 02 sensor, please exercise a little caution.
Narrow band sensor cost about RM400. Wide band sensor is about RM3,000~5,000.
evo3
1,794
24
from wat i heard from my friend on Apexi TT reading is not "very" accurate .... if i not mistaken there is a disclaimer in the Apexi TT manual that say the reading are for reference only....hehehe :)
acbc
4,615
KD
In other words, the A/F Ratio Meter is for deco purposes only la... :P
I'm using the AutoMeter A/F - feel like selling it off cheap already.
Joeker
Walking Dead
3,580
62
Jinjang
Not exactly so.
A stock engine operate at narrow A/F ratio anyway. So I guess the A/F meter although coupled with the stock narrow band 02 sensor, is displaying correct A/F reading as far as stock engine concern.
Hi guys,
I have a 2009 Perodua Viva all with original stock/condition. This car has been performing well for my daily usage to commute to work (short distance around 30-40km daily). Now i have change my office to shah alam, hence daily commute distance is more than 100km daily.
I never modifiy/upgrade my car, so i am really noob in terms of car upgrade. Pls recommend any modification/upgrade i should add? My aim is comfort & stable cruising speed/vibration on highway. Speed/pickup is not...
