How to make wira rear suspension high?
^Dreamerz^
1,523
KL,AmPang..
dont rojak ur suspension, not a wise choice..
take something which is build for ur car spec..
honestly, adjustable will be the best choice to get higher ride, also lower ride.. just my 2 cents..
sy_omar
287
Kinrara
I use mirage front abs with 1.6 spring.... on my mum wira... front little bit high... so i buy kayaba gas abs for rear.... it can adjust the spring holder to make it high... so my mum car level already.... and rear abs really work good. kayaba gas abs ... cost rm65 each.... so now when we load 3 person behind.... the car still level..... even put lot of thing into rear compartment.....
basikalmerah
64
you can oso try 1.8 mitsu at the rear, very comfortable drive and better than proton standard shock
hi every master,
i am want to DIY cold air intake...
the purple line inside the picture which is my planning connection...
the circle part is i want to drill it...
the hole which i make it from drilling ... is still inside the front grill ... so the water would not easy flow inside to my hosepipe...
er... i just want to ask is there any disadvantage for my planning ???
i am thinking quite long time ago .... but...
