how to make DIY shiftlight
donCityZ
2,293
33
wah.. nobody done this before?
wait for it. im gonna DIY this soon for my car but need to do some r&d first.
if success, then i post in DIY section.
miriguy
887
20
any success story yet?
jswong
209
9
If we can tap voltage input to tacho's coil, then all we need is an analog comparator with a variable resistor to determine which is the comparison point to flag a "higher than reference" condition. This is the low-voltage stage. Run the output to a Schmitt trigger (positive feedback op-amp only) to turn the signal into a higher-voltage on or off instead of a variable signal, and to a voltage-follower amp (buffer op-amp) to drive a lamp.
I think this entire circuit can be designed from a few op-amp ICs.. but since the moving coil input voltages are usually very small, that will mean we'll need a small reference voltage also.. so we might need a low-voltage reference output IC also, e.g. a temperature-stable 2-volt reference IC.
donCityZ
2,293
33
haha.. i tried to search the rpm signal from standard connector of my car.. but cant find any.
now thinking to do my own detection by a simple coil wound around the plug cable. wahaha..
but, this r&d is difficult cause i dont have an oscilloscope.:banghead: lend me an oscilloscope then i can finish it in 1 day.
Bump: haha.. i tried to search the rpm signal from standard connector of my car.. but cant find any.
Honda Malaysia has announced plans to provide a free-of-charge service to replace the fuel pump unit involving 55,354 cars nationwide. This is a precautionary measure that is in line with Honda’s global fuel pump recall. However, no Hondas made in 2020 or onwards are affected.
“All affected customers will be informed via notification letters, which will include details of the product recall. Honda Malaysia urges all affected customers to contact any Honda authorized dealer to make an...
