How to make 4g64T hi rev motor??
nan83
238
35
3,028
Pasir Mas,Kel
hi all...
i hope all can give input about 2.4 block hi rev.... i'm going to rev it around 8500-9000rpm. I know base on calculation it safe only at 7500rpm..
huumm... but kiggly already proof that 4g64 with 150mm rod can make 9600rpm .... what is the secret??
hoping all of us can share some tip to make it happen... thanks.
forged conrod,race engine bearing,forged piston
and the most important after above parts installed.....FULL engine balancing (static and dynamic)
even better u can grab billet crankshaft for this setup...
thilaksharma
From Facebook
Sep 21, 2011
60
19
508
www.facebook.com
if u follow kiggly's threads in dsmtuners, he already claimed that he changes his rod bearings each race , he have quoted that beyond 7850 rpm his bearings are confirmed to start getting defacts n after the race he changes them
I am building a 4g64 with slightly higher rev than the stock , after all the research and inputs from evom , try googling "john bradley 4g64LR" , u will get lots of anwsers :D
After much research, the only way u gonna rev higher is lightweight rods and lightweight pistons , and of cos change the rod ratio with a longer rod
4G64 Long Rod can be achieve with on the shelf pistons 4G64 Block , 100mm crank , 156mm on shelf rods , short stroker pistons
lightest rods are of cos aluminium, R&R , Groden & GRP , if steel , H-Beams are lighter in the 5XXgram range for manley, eagle scat but the champion light H Beam is K1's , lightest I beam will fall to Oliver's
Pistons wise, sorry to say, depends on your HP , 4032 Forged pistons are much much lighter but they would not stand the HP of 2618 Forged pistons. After much research, the lightest pistons will drop to Supertech, Manley and the lightest is JE's latest 4032 pistons.
There are some guys who went 162mm rods with the 100mm crank, but the piston is beyond weird, the offset of the pin is so high and u need to custom order the pistons. The cost for a 162mm setup is not cheap further more 162mm rods are not available in aluminiums. They are somehow discouraged , its nt even listed in Magnus's engine catalog
the main reason why 4g64's cant rev is piston speed is to high and wear on the conrod bearing, thts the reason 4g63 2.3 stroker can rev a lil higher than 4g64 stock , cos of reduced weight on rotational parts
bt of cos kiggly has his HLA's to limit oil to the head and engine out from starvation. its been a long time i have been updated on kiggly's machine, any update guys ?
nan83
238
35
3,028
Pasir Mas,Kel
humm... this is what i found some info that kiggly(kevin) post in dsmtuner & evom...
1. about bearing clearance & oil
If you're running 10w30 and not crazy power levels, you should shoot for near-stock clearances. In untouched DSM engines they were usually in the 0.002-0.0025" range. In the drag car I'm running 0.004" now with 25w50. I wouldn't want to try this loose of oil clearance on light oil though.
2. Mod wet sump
You can also fix all the oiling issues with a modified wet sump (i.e. - conventional) for more capacity by going deeper, a better pickup tube, and a windage tray. I have no oil pressure dips at all on the track and have logged this every pass for about 4 years. It is just now that I have everything sorted out to where I don't see some fall-off somewhere, just a constant 85-90psi. The center main bearing issue is not starvation or aeration. As far as I can tell, all our pump issues are oil pan and pickup related. If you run the pump without oil or with interruptions in the oil supply, it eats itself up. The honda engines definitely have a better developed oil sump/pickup system in OEM trim. This also takes its toll on turbo bearings.
3. Lighter parts
They wipe out center main bearings due to high bearing loads from a combination of light counterweights on the crank and heavy rotating parts. It may be possible to increase the counterweights to fix the bearing loads, but then all the bearing loads are very high. I'm attacking it from the lighter rotating parts point of view. I'm also trying some looser main bearing clearances this season to see if it helps. The bearing failure mode looks like overheating of the shells. At OEM clearances the center main bearing will be wiped out in somewhere around 20 passes.
4. Groove Main Bearing
A non-grooved center main bearing (like our OEM ones) would gall or wipe out in about 10 passes with my old setup. After grooving the main bearings they would go for a season. I think it is a bearing overheat issue, not a film strength issue. The slotted bearing flows more oil and cools itself better. I've been revving my 2.3l to 9k for several years now - you just need to add full diameter oiling grooves to the main bearings and they will live. 1/8" wide grooves, cut down to the bearing backing
5. Other info
- The main bearing issue is the lower center main bearing. If you run through all the combined inertia and cylinder pressure loading calculations you'll find this is the highest loaded bearing. The bearing loading is also tightly tied to counterweight mass. One reason I would be keen on checking out some of the aftermarket cranks is they could have a higher counterweight percentage to counteract the inertia forces at high rpm. I don't think the OEM 7-bolt has any strength issues, but I think it has the same inertia and bearing loading issues as all the 6-bolts.
- The problem with revving a 2.3l high is main bearings. This situation hardly changes at all between a 2.3l and long-rod 2.4l. For that matter, the piston acceleration advantage with the extra 6mm rod length is also very, very small. I didn't see anybody put any real numbers to this, but I believe it is less than 200rpm for the piston acceleration difference. Add the 6mm worth of extra rod length/weight and it is pretty much a wash. I see the only advantage of the 2.4l as the slightly lower rod angles for less cylinder wall wear, but with where the Wiseco stuff is going for skirt shapes the wall wear really isn't an issue.
- I've never balanced a crank, nor have I ever had any material cut off one. Its good to balance all the parts to each other, but as previously stated, they usually don't vary much at all. I just balance the pistons to each other and run it. I had several seasons on a 2.0l going to 9.5k like this and about 40 passes and 20 dyno pulls on a 2.3l going to 9k (other changes are req'd on a 2.3l at these rpm's).
- I've been spinning the 2.3l to 9200rpm for a little over a season now. The center main bearing doesn't love this, but lives if slotted/groove and seems to also like more clearance. The real fix is either more counterweight on the crank or less piston weight. I'm working with Wiseco on some parts to go higher than I'm going right now reliably. Then there is the issue of keeping it breathing up there...
other supporting mod
1. kiggly HLA
2. install Main Bearing Cap Alignment Dowel
3. mod thurst bearing ( chamfer )
4. magnus dry sump kit... usd5000 huhuhu
fuu.. tired searching... but got some good info ...thanks google... huhuhu..
---------- Post added at 12:36 AM ---------- 6 hour anti-bump limit - Previous post was at 12:25 AM ----------
what about de-stroking it?
2.1 destroking.... that for who wanna rev to the moon... kekekeke
9000rpm can be done nicely with 2.2 & 2.0 setup ....
now i want fast spooling, nice torque & below 9000rpm rev.... 2.4 with nice build will be my choice.... or maybe 2.4LR can give me more safety margin.... huhuu..
I've 1 HKS 3037 turbo need repair, the bearing come out oredi.. any workshop is the most recommanded or anyone here can pm me if u're doing repair turbo service..
roughly how much if repair this kind of ball bearing turbo?
