how far 1.6 can rev?
qimme
76
p/s : emmm..auto gbox for 1.6 is controlled by ecu (it have transmission control unit) right? from what i understand 1.5 auto cannot fit 1.6 auto gbox due to this reason..meaning it is not as simple as changing a 1.5 auto gbox to manual which is just like plug and play because it's mechanically control..try asked the mech back if the transmission control unit has been disable, or can be disable or need to change the ecu to manual ecu..
im changing my 1.6 auto to 1.5 manual la... if not mistaken my pickup are same like evo3.. in first n second gear.. but my rpm short... evo3 got long rpm... so if he in first gear, my car need to change second gear... if he in second gear, my car all ready 3gear... then bye2 my car... only can follow 2 gear only... that is how to discrible my pickup..
afmarsyal
100
6
i concluded this case as engine rasa kuat tapi pegi tak cepat2..
what i'm trying to say is, have you check your ecu or trasmission control unit compatibility with the gbox..but nevermind la..i got one friend change 4g92p auto gbox to manual 1.8..happy ever after..no need to change ecu or disable transmission control unit..but if change better, engine much smoother because there is manual ecu and auto ecu..confirm got different..
why u change to 1.5 manual gbox..? do you know that from the user manual, the manual gear drive for 1.3, 1.5, and 1.8 is the same, including the reverse drive? except for 1.6 the final drive is the same for 2.0 diesel that is 0.756 compare to the rest, 0.777? but except that all the same..first gear = 3.363, second = 1.947, third = 1.285, fourth = 0.939..the difference is at the flywheel..
and oh, do you know the 1.3 and 1.5 standard flywheel is lighter than the 1.6 and 1.8 standard flywheel? 1.3/1.5 flywheel is even smaller than 1.6/1.8 flywheel..see the clutch plate..the rest is for you to judge..for me right now your car is like using lightened flywheel eventhough your using standard 1.5 flywheel..why? the power u need to spin the flywheel is abundance but the inertia of the flywheel not enough to take you flying..same like 1.5 potong ringan flywheel end up no top speed..try unskimmed supertouring flywheel first, not more than rm400 solution, that is if it solve your problem la..and you will loose all that evo3 power, but gain top speed
guess that also answer sifu sky and tofu question too..happy motoring
qimme
76
ayioooo... sorry afmarsyal.. forget to tell u laa... 1.5 manual, with 1.6 flywheel n 1.6 clucth plate... heehehee.. so sorry... i change coz gearbox computer prob... so "mahal nk tukar" then make my mind to play manual... "Baru Laki"hehehe
so like u told me earlier, supertouring flywheel... "rm400 siap pasang ke"?? by the way i kinda love the pickup... can 4 n 5 gear change hah?? hehehe.. :biggrin:
Bump:
wira with twin weber dcoe and 292 cams...:adore:
wahhhhhhhh!!!!!! so power full ... what horsepower gain from it??? tell me, tell me skywalker:adore:
afmarsyal
100
6
emmm..your 4g92p with 1.5 manual gbox is common setup for people to play drag..
but if you have already put in 1.6 flywheel and clutch no need to put supertouring..yes rm400 complete install, but no need la..already 1.6 flywheel and clutch..should be ok..even the gear drive is as i explain, so now your gbox is quite similar setup with 1.8gbox..
i don't know where gone wrong, but for your info, auto ecu tends to 'melahu' or overrev abit compare to manual ecu..this my friend explain..and auto ecu and manual ecu is different..maybe auto ecu couple with problematic gearbox computer cause your problem..
however, try to look around..there a few threads about this, some post different problem, but can study about gbox working principle and parts..
maybe unicornspeed is right, 1.5 gbox just not made for 1.6..however my advise, solve this problem first, get a usual rpm to speed condition rather to get 200km/h at 7500rpm..4g92p got rev limiter of 6500 - 6700rpm and it exist for reason..
gud luck and happy motoring..
p/s: owh, i just knew that there is synchromesh thingy in manual gbox..i don't know if it is the same with 1.3/1.5 gbox and 1.6/1.8 gbox..could be another contributing factor..
tofu_manic
1,342
91
not really....i mean....imagine if u r an engine...and ur max ability to spin something is just say 8000 rpm...i think it would be easier (using lesser energy) to spin something really light to reach that rpm, as compared to something heavy
interesting article i found: http://www.pumaracing.co.uk/FLYWHEEL.htm
afmarsyal
100
6
aiyah, very long article that one..nearly muntah oredi..so many equations with many unknown..hehehehe..some more in english..(aiyah SPM not very good english, plus want to read more math ka? :) ..)
however, many cases reported with lightened flywheel, less top speed, but faster acceleration..
so tofu sifu, your flywheel lightened or not? my supertouring finally got lightened.. :p boring la waiting from 140 - 170km/h, that's why i skim..now much easier..but top speed same..
owh, standard skim supertouring flywheel still heavier than 1.5 standard flywheel
tofu_manic
1,342
91
mine is lightened/balanced as well....going uphill/topspeed no noticeable difference
as for those who lost their top speed, mebbe their flywheels were not balanced properly? hence loss of upper revs? haha i donno
so when u lightened ur supertouring flywheel, top speed maintained the same, so that already shows that not necessarily the heavier, the higher the top speed
yeap, oh well....i donno also...not a math person as well hehe
afmarsyal
100
6
hahahahah..same here.. :P
tofu sifu, can explain more on synchromesh ka? i want to know to what extend is 1.3,1.5,1.6,1.8 is different..i know that it is the thing that catch the gear inside gearbox..but got any difference ka? bigger or smaller..?
i believe the difference of gear drive and flywheel we all ready know.. :)
tofu_manic
1,342
91
no freaking idea dude, i have not yet had the chance to dissect the stuffs hehe
never bothered searching also since it never bothers me haha
DEFI LINK METER ADVANCE ZD
Release :May 24th, 2010
official defi link
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/mjoLiZ0tTZY&hl=en&fs=1"></param><param...
