Honda SM4 Engine Conversion
Amedion
1,193
Teluk Pulai
amedion.fotopic.net
like i said.. RM3k~rm4k is not enuff for H22A.. u can take Twin Cam engine non-vtec.. rm2k+ .. i got rm4k+ also dun dare to go for h22a.. when they install ar.. sure dis n dat cannot use.. then change.. even small parts rm25 also can make hole in ur pocket.. timing belt rm160, atf rm1xx, spark plug rm6x, oild fluid n filter rm8x, gaskets n seals all depend on the condition.. mounting point also must change.. many stuf la.. rm6k ++
s15
1,023
KayElle,JayB,Sg
www.revsaints.com
where u stay??
s15
1,023
KayElle,JayB,Sg
www.revsaints.com
so far away...
can't help u :P
sfoofs
20
hi mazdaspeed,
r u interested in sm4 side skirting...ori p.u. from chop shop.
price rm 300 (neg) :)
h22a.....the last i asked, rm 4.5K for haf cut... wit ur budget tough le
good luck :)
I
Indecided
Guest
Don't forget u're converting from F20A SOHC CARB engine ler..
a lot of wiring work needs to be done..compared to a EFI drop in.
Cables routed for ECU..etc...it's not really a small job but nothing too big that a typical mechanic can't handle.
Personally i'm a F20B fan... same roadtax every year, economical, and if you feel lazy get the tiptronic version from the Accord Euro...
Too bad the car's going anyways.
mazdaspeed
17
gee.... wut is tiptronic?? is it the same wit the salespeed kind of thing?? hehe... no idea la... hmm about the engine, i guess i'm not yet ready for the H22A transplant... F20B sounds reasonable..any idea how much it costs? emm... what is the diff between F20A and F20B? thanx for all replies...luv u lahh!~ ahahaks
s15
1,023
KayElle,JayB,Sg
www.revsaints.com
[snapback]839089[/snapback]​
tiptronic has same idea as selespeed
but the mechanism is totally diff.....
selespeed is same like manual..just that mo clutch
but for tiptronic..u just push and pull to change gear
F20A and F20B lotsa diff...
cost is 10 times diff...
F20A can get 1.8k front cut...
F20A need 13k above :rolleyes:
btw...me not gay here :lol: :P
sfoofs
20
yen na ra? so F20A is 1.8k or 13k?? F20b is DOHC VTEC tiptronic gear + dig. meter from CF4..
[snapback]839919[/snapback]​
[/quote]
wah...so cheap meh F20A? I asked around cost abt RM 2.3K ler... :unsure:
The Marketplace Top Posts
Is anyone know where can i buy the arb bush? I already change my rear arb
to mivec arb, which diameter is 16 mm. Most of the spare part shop I went,
didn't has this part and I just bought one but cannot fit. Any advice from
you all. Thanks.
