-CIVIC EK/EJ 96-00 REAR LOWER CONTROL ARM ( BLUE/RED/GOLD/TITATIUM/SILVER ) = RM340
-CIVIC EG 92-95,CRX 93-97,INTEGRA 90-01,CIVIC 88-91 REAR LOWER CONTROL ARM ( BLUE/RED/GOLD/TITATIUM/SILVER ) = RM340
for honda eg car: to fit rear control lower arm the rear absorber need to be change using ek/ej rear absorber before fixing. tq
-CIVIC EK/EJ 96-00 UPPER ADJUSTABLE CONTROL ARM = RM350
-CIVIC 92-95, CRX 93-97,INTEGRA 94-01 UPPER ADJUSTABLE CONTROL ARM = RM350
-INTEGRA 90-93 UPPER ADJUSTABLE CONTROL ARM = RM350
-CIVIC 88-91 UPPER ADJUSTABLE CONTROL ARM =RM350
-COILOVER SPRING KITCIVIC,CRX,ACCORD
COILOVER SPRING KIT CAN BE FITTED TO:
HONDA CIVIC CRX 1988-2000 ALL MODEL
HONDA DEL SOL 1993-1997
HONDA PRELUDE 1992-2001
HONDA ACCORD 1990-2002
HONDA INTEGRA 1990-2001
COILOVER SPRINGS KIT WORK WITH ALL STANDARD SHOCKS. IMPROVES HANDLING OF THE VEHICLE IN TURNS, REDUCES WHEEL HOP AND IMPROVES WEIGHT TRANSFER DURING HARD ACCELERATION, IMPROVES THE APPEARANCE OF YOUR CAR.PROFESSIONAL INSTALLATION IS RECOMMENDED.
#REAE LOWER CONTROL ARM CIVIC 88-91 ( MODIFICATION NEEDED )
REAR LOWER CONTROL ARM:
*MAKE OF HIGH QUALITY FORGED ALUMINUM & LIGHT WEIGHT
*IMPROVE HANDLING & STABILITY WITHOUT PREMATURE TIRE WEAR
*PROVIDE LIGHT-WEIGHT PERFORMANCE WITH AN ENHANCED APPEARANCE TO YOUR CAR
*REDUCE AMOUNT OF CAMBER WHEN LOWERING VEHICLES SUSPENSION
*CONTROL ARM KIT DESIGNED TO ALLOW THE USE OF WIDER WHEEL
*MAKE A GREAT UPGRADE TO ANY OLD WORN OUT UNIT
*THE LCA ARE STRONG AND REMOVE ABOUT 2.5 POUNDS
*INCLUDES SWAY BAR PROVISIONS AND HARD RUBBER BUSHING
*PROFESSIONAL INSTALLATION IS HIGHLY RECOMMENDED
UPPER ADJUSTABLE CONTROL ARM:
*MAKE OUT OF GRADE A STEEL ( NOT RUSTY SCRAP METAL )
*POWDER COATED FINISH
*ADJUSTABLE RACING BALL JOINT
* COMPLETELY REPLACE FACTORY ARM FOR A FULLY ADJUSTABLE
*CAN BE ADJUSTED TO CORRECT -4.5 DEGREE TO +4.5 DEGREE CAMBER
*GET LOGER TIRE LIFE AND PERFORMANCE FROM ANY LOWERED CAR
*HIGH PERFORMANCE BUSHING TO IMPROVE HANDLING
*ENHANCE LOOK AND PERFORMANCE ON ANT STREET,TRACK OR DRAG RACE CARS
* A MUST IF U HAVE LOWERED YOUR VEHICLE
*WORK WITH ALL AFTERMARKET LOWERING SPRINGS AND COILOVER KITS
*EASY TO INSTALL,BUT PROFESSIONAL INSTALLATION IS RECOMMEDED
Serious buyer please call 012-4523226 to place your order.
Item condition: New
Item Location: Penang, Nibong Tebal
Transaction: Maybank2u, Cash deposit, cash
Delivery: Poslaju, Self collect.
For other performance part inquire please email [email protected]
VISIT : t-performance.blogspot.com
Thank you.
Item condition: New
Thank you.
