High Power Ignition Earth
andysky5
33,386
55
Brand New Earth strengthening system specially designed for ignition.
Engine performance is greatly improved due to a more stable ignition which is brought about by double effect of a strengthen earthing system and noise filter circuitry that quickly suppresses noise when the ignition coil fires !!
Very easy to install, can DIY....just connect it between your engine cylinder head cover and your battery negative (-).
- Improve Ignition Power
- Increase low end Torque and Power
- Reduce fuel consumption
Price : rm140
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at PJ/ Kelana Jaya/Sunway or Send by Postlaju.
CLICK HERE to check out my other sales Item !! :burnout:
Thanks for Viewing !!
ariolz
242
does it work with grounding cables? if it works i want one
viostar
475
Brand New. Very easy to install, can DIY....just connect it between your engine cylinder head cover and your battery negative (-).
Price : rm130 nett
andy,...
This product from where? Taiwan ka?
Speed75
171
Bro, Can U explain a little bit about that item bro?
Like what it suppose to do?
(If U don't mind)
cancer5854
15
Hi bro, I dun understand where should I connect to my engine cylinder head cover. Which part? Can show me a more detail photo or picture?
Thank you.
andysky5
33,386
55
Thank you.
Hello bro, you can attach to the screw at any part of your engine head cover......the effect is to improve the grounding electric and there is a chip inside which helps with improving the ignition efficiency and power :driver:
