help
eghadi
40
engine shaking when ideling,wat the prob?anyone can help?
eghadi
40
but the rpm drop to 800,very low ideling.
Northiswara
2,589
7
check spark plug.
clean throttle body
check spark plug cable.
fobs
3,752
eghadi
40
not normal for me,if press to 1200rpm,no vibrate.oledi change spark plug.
fobs
3,752
for most car is normal,...
even ur EG should not idle at 1.2k
that means u have to chk ur mountings,... i suspect that is where the problem is
Northiswara
2,589
7
air cond pun reach til 1k rpm max.
Northiswara
2,589
7
shud be same with or without a/c if engine is healthy...
wats ur idling rpm??? r u on stock cam??? - - idling more than 800rpm??
check ur vacuum hoses...n distributor rotor..
mine with air cond on, rpm naik sikit, 100-200rpm.
on bigger cc car on and off air cond make no difference to rpm at all. mine is 1.6 only.
eghadi
40
thanks for the advise,will do it letter coz im outstation.my eg turbo power eh..........
Hi
I've got a problem with the front drive shaft (left side).
1) Anyone know why there's a some sort of an oil leak at the front drive shaft?
2) Can be repaired or need the replace the shaft?
3) Dangerous to continue driving?
4) What happens if the condition is being left as it is?
Some pictures below. Thanks.
