help!
cKLee
26
KCH
can gif all the opinions u haf 4 ATOZ?? PLZ GIF ME GOOD n BAD opinions 2...OK?? thanx!
:lol:
ezwong2002
452
Butterworth, Penang
www.geocities.com
get the 1.1L version. the previous 1L version is way underpowered..
problems i've encountered with the ATOZ 1L
1. Rear drum brakes gives crackling sound... mech unable to fix the problem for good.. but it does no damage tho..
2. The revs unevenly during pickup.. also cannot be solve even tho the ECU has been reprogrammed.
3. Underpowered.
4. No ready made bodykits available.
5. No performance kits.
cKLee
26
KCH
:) o...thanx 4 ur little opinion! so..U mean atoz 1.1 is much better than atoz 1.0 la? ask some other ppl 2 gif comments 2...OK? THANX VERY MUCH~~~C U!
:D
drill
617
12
5,018
Damansara
yaya no power at all....
err ezwong...do u mean the 1.1l is the one from inokom or hyundai?
vance63
5
i suggest u to modified ur center catalytic converter, change to straite bullet, take out ur original filter piping :unsure: :)
ezwong2002
452
Butterworth, Penang
www.geocities.com
i had the catalytic converter removed, only very slight increase of torque. ok.. who has the ATOS 1L ECU wiring diagram here? called those service centers.. and they aren't of any help.. bloody morons.. only know how to change engine oil.. that any mech also can do la.. stuck up hyundai.. two thumbs down for 'em inokom for asking a favor from them...
Dun have ECU diagram nevermind.. at least show me the RPM signal wire.. hehe.. i plan to get the DEFI look-a-like RPM gauge for the ATOS.
bird
7
i'm also looking for the ecu wiring diagram, cause going to add apex'i rsm & s-afc.
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
ah bird.. u wait slow slow la.... if u are staying in KL... go straight to Hyumal .. they are the authorized service center for inokom and hyundai cars.. what i know is that they have a CD containing all mechanical and electrical information. The thing is that.. how can we can hold of that information. What Hyumal people say is that i have to go there and get it... shit... so bird.. do us a favor and get 'em CD for the sake of hyundai/inokom owners.
cheers!
p/s : bring a blank CD for them to copy just in case :D
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
ezwong,
did you try the glemarie Hyundai SC HQ for the ECU? i suggest you walk in, if you call those lady will not know what you are talking about... ;)
does anyone noe da max spring diameter can a satria take at the rear????
those original satria rear suspension mount, can take wat diameter? anyone noes? urgent...!!! coz i hav a tein HA, which uses a taper styled spring, its smaller diameter at da bottom n bigger on the top...its 70mm at bottom 90mm on da top...
http://www.jaydm.com/tein/standard.htm - can refer ere for da type of spring im talkin bout
thanks
