Help to mod my satria!!!
krackie
11
hello to all car experts, i juz got a satria year 96'..i wanna modify it to in and out..change everytin bout it..hahha..need some help and recommendation here.. if anyone selling any complete mivec or gsr engine can also tell me..pls pls give me some tips on how to mod the performance part..kinda noob..thanks alot!!
allance
337
8
1.port polish head
2.high compression piston
3.stage 2/3 high cam
4.light weight flywheel
5.racing clucth
6.adjust cam pully
7.4-2-1 exhaust header
8.open port airfilter with cool air intake
9.fuel ragular
10.shorter intake manifold
11.large saiz thorttle
12.e-manage ecu
13.high performance 12mm cable plug
14.iridium plug
15.thin metal head gasket
16.voltage stabilizer
krackie
11
alrite..will take note of all that..thanks for the suggestion allance..
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
with all that power, dont forget strut/stabilizer bars n good braking & suspension system
krackie
11
haha..thank u so much for da suggestion..
beatnik, i dun mind bout budget..can do abit abit la..
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
if u dun mind budget, ur mods easily go up to 50k without realizing...prolly just engine stuff only
fadlie
68
1,508
1.port polish head
5.racing clucth
6.adjust cam pully
9.fuel ragular
12.e-manage ecu
14.iridium plug
what is the cc of this satria? 1.3 or 1.6? if 1.3 don waste ur time and money to do all this mods...
better straight to engine transplant...
Shinjite
864
120
1,543
Klang
pair it up with a good set of suspension + brakes
and also reinforce the chassis, you can go autofoam also
sr18autech
Banned
Jun 27, 2009
209
5
for practically + horsepower, u can buy a 4G92 Sohc or Dohc (Sohc for low-mid pull, Dohc for mid-high pull....but in the end of the day skills matters the most) strip the engine n complete rebuild and blue print it. Putting a 260lift cams and port n polish the engine head. Replace all pulleys with aluminium ones. Remember to add an Oil-Cooler for pleasant high-revving obsession....Hook up Emanage or Unichip and You should be enjoying about 130-140whp / 150-160wtq at it's best. (Under skillful hands, this sohc 92 can be very competitive againsts mivec and vtec)
Estimation is RM7000-8000 for such project (just source engine lantai + ecu + injection kit will do)
For handling, use Enkei rims 14" - 15", using good tyres.....Get a fully-adjustable suspension is more crucial, test drive it n get used to the handling upon ur own preferences
(chassis stregthening is the last thing u want to improve, coz stiffening chassis doesnt means is better handling most of the time, chassis needs to flex to ensure grip n prolong chassis life, too stiff might crack n spin out)
krackie
11
im thinking of doin engine transplant oso..now mine is juz 1.3..
for body, i already did everytin..left paintin da car and addin rims oni..u guys know any shop can do matte black paint?
Local Models
Blue price: height adjustable kit (hi-lo), spring rates of your choice, for ultimate tunablity, be it street sport or all out racing.
Red price: fixed spring seat, using your stock springs, for the ultimate in comfort. An Original Equipment compatible replacement.
(usually for Family...
