Head Light On, RPM Drops !!
Hi all sifus, newbie here, please help me, thank you a million in advance.
Car:
yr2000 P.Wira 1.5(A) EFI sedan
Problems:
1) When i switch on head light, my RPM drops significantly, worse if combine with a/cond compressor running + engage in D gear + car stagnant (eg stop during red light), even worse if sudden brake, rpm drops so low until engine like wanted to stall anytime. When idling in N level without a/cond, RPM is ok, around 850, running smooth & steady as before.
2) Fuel consumption worsen after recent installations (see below) :<
What recently did to my car:
1) change alternator to non-ori 90A type (ori is 80A), -ve terminal of batt dismantled for half an hr while installation, after installed immediately tested that it charging batt @ 14.x V while head light & a/cond turn on. I didn't change alternator belt, just use back d ori belt.
2) change both head light bulb twice, fr ori Philips to Narva 4500k, after few days then change back to ori philips, both (60W/55), also tried installed HID for few minutes for demo by accs shop, then uninstalled it.
3) change fog light, left side fog light wire cut & rejointed, as d lousy accs ppl cant pull out the wire's socket-joint thru bumper hole
Besides, the moment when turn on key to ignite engine, i can hear a sound like belt squeeking, only last for 0.5 second then gone when engine starts running.Dunno which belt, but i suspect its d alternator belt. :<
So, Sifus, what problems is this? wiring messed-up? tuning out? belt too tight/loose? ECU reset? (0.5hr disconnect batt can reset ECU already?)
Pls advice
Car:
Problems:
Pls advice
