gsr block and 4g93 block
putra888
24
heloo sifu sifu help out there
now im using GSR turbo block...
my problem is the custom form hilang,,,
so can i use 4g93 block ,,,
put back all the turbo stuff , piston turbo, crack shaff all thing laaa but use non turbo block 4g93
some people say ok'
confrim gam...
people say diffrent is the piston olny
help me
gsrTurbo9166
958
yo bro
4g93 block is a NA block
it cant stand the pressure from the turbine
at first the block sure can stand the pressure but for long then the block sure die 1
so think carefully b4 u do ur modification on it
AlucarD
1,079
115
5,163
93P and 93T block is different. I would use back the 93T block.
chris2000
1,114
24
some people say ok'
confrim gam...
help me[/QUOTE
The internals like the rods are stronger material in a GSR.
The Main difference between the 93P and 93T is the 93T has oil squiters below piston. Everything on the 93T can transfer to the 93P including crank, rods, pistons, head, water cooler. Only the oil squiters can't be transfered unless sent to engineering shop to drill holes in your 93P block but not reliable.
Zeroed
1,705
45
Lots of opinions on this eh.
My mechanic (rebuilds about 1 engine per week, reputable) tells me that other than the additional oil squirter and the piston compression, the rest of the parts including the internals are the same. These two are basically the same engines, with only the necessary parts changed to accomodate forced induction - lower compression pistons and additional cooling. That is atleast what I have learnt so far la.
I havent done so myself, but we can check the parts number to see if they are the same...
wanwrxSti
142
myhouse
bro...why not you just go back to the shop you buy the engine..ask them for another photocopy of the customs form that you lost it...............BUT..you have to pay them! i pay for my customs form too..(rumah tebako)..u pay them about RM50...try your luck.. :smile:
putra888
24
hmmm
the problem is buy atas orang,,,
so the guy missing in the action,,,
dont know still alive or dier readyyy...
Yong_5290
3,637
49
Klang
hotmail.com
wah...not tat low kua...4g91 also got ppl boost up 2 0.8bars wit thick metal gasket n 180hp on wheel
Castrol, the proud sponsor of the UEFA EURO 2012 tournament just concluded their first phase of their "Castrol Ada Kick" contest where thousand of participants have been filtered down to a final 20 in order to do battle in the next phase, just to stand a chance to win an all-expense paid dream trip to watch the UEFA EURO 2012 live in Poland in June 2012!
<!--more-->Designed...
