Grounding Layout
mzh82
100
6
what layout do u need act? izzit the gounding cable dat connect to -ve terminal on ur battery?
edwin_lcw
1,242
Setapak
yeah ..... where is the points ...... n best got pic lo
mzh82
100
6
from wat i understand, the grounding is to improve effectiveness of ur electrical system. its performance can be obvious for old car. but for new car such as satria neo, the effect will minor because nowadays car has improve their electrical system from the factory.the concept is to make additional route for current to travel from ur electrical devices back to battery.
so, ussually the grounding cable is attach to:
1)-ve terminal on the battery,
2)alternator
3)firewall/body
4)engine head
so, gudlaq
hisha
2,016
7
another point ...from ur exhaust to ur car body ....
The Marketplace Top Posts
Seriously a series of car faults these days....
I went for a manual transmission fluid change. I brought my own gear oil. After draining my transmission of the old oil, it was time to fill in the new. The worker used a machine that was meant to flush ATF to pump my new gear oil into my gearbox. I wasn't sure if that was the standard procedure, so I kept quiet but made sure he flushed the machine thoroughly. And I did ask him to run the machine through with more fresh gear oil.
Long...
