Gear ratio speed
Zat Fero
From Facebook
Dec 23, 2010
16
503
www.facebook.com
Have you ever wonder, how much your gear ratio SPEED ?
Can it goes up to 260kmph?
Well if you have all the ratios,final drive and your wheelsize diameter. You can calculate manually (using all the formula) or you just can fill in the blank in this awesome website http://www.apexgarage.com/tech/gear_ratios.shtml .
* You can see changes between wheelsize diameter affect your topspeed as well your rev(rpm).
I hope this helps anyone searching for this gear ratio speed calculator .
* Good luck!:wavey:
hi,
last week i just install my turbo timer on my standard N/A engine
is a full auto turbo timer
the problem i facing now is,
sumtimes when the engine still runing,i wont be able to lock my door
izzit my timer problem or my alarm system problem?
pls help
thanks
