gear changing noise
Burnz
19
hi to all vtec owners,i m having a problem of changing gears during high rpm especially during the vtec kicks in, there's a crack sound when i change from 2nd to 3rd and 3rd to 4th its hard 2 change it sometimes.I believe some of u haf experience the same problem like me.I haf change the gear oil every 20,000km but the prob still remain.Is there any solution to solve this problem?i afraid it will damage the gearbox..
Areignz
281
Synchro problem bro...common vtec gbox problem but can be repaired.Try to change to motul gear oil first if it can helps.If not overhaul gbox lah.
bugsy
41
seremban
guys just wanna know, for b18c gear box... to get the syncro mesh repaired... how much will it cost??? and also, if wanna overhaul whole gearbox how much will cost more or less???
prasath_5338
1,131
19
hmm im facing that problem also.....very hard to upshift towards end of power band. i usually kind of force it to engage. any idea why?
shiroitenshi
3,676
170
heh, total overhaul of gearbox will be around 3K minimum, depending on parts & labour
A used gearbox is lil' cheaper than that, if Y21.
If S80. don't think it's that cheap anymore.
There's also the choice of non-oem syncros from Gearspeed Inc. Price wise, I'm not sure with the current exchange rate.
raining
188
10
kuala lumpur
i'm facing the same problem in my S2000 gear box too,from 1st to 2nd crank sound,but only during low rpm. If high rpm there is no sound:confused:. Or maybe the sound was covered by vtec sound when high rpm so cannot hear it.:driver:
king_jamez
551
i'm having problem wit the noise from gearbox and jerking when changing gear from 2nd to 3rd on my eg as well...is it because of the dirty oil?
Shoken7
193
i tot i was the only one!some mechanic told me to change my "copper" or "coupler " cant remember what is it he said..that would cost about rm700 :SS so i put that mod on hold .since i got other things that i wanna repair first
How frequent are we suppose to change our gear oils? i havent changed it for the past 2 years
SimonsayZ
155
Puchong
Haha, I have that crack sound only on 3rd gear at high rev. It really is annoying...I believe its syncro problem. Though I also suspect my mounting on gearbox side is kong already. Btw, mine is B16a.
akuma
3,489
152
Kuantan
synchros problem everywhr..welcome 2 d club....so,while i try 2 safe up enuff 2 fully overhaul my gbox(buying a used unit is a 50/50 gamble too,aight?).....wat i do i i drive slowly enuff n always TRY 2 double clutch whn i shift up..
so far,its working 4 me.....any bozos trying 2 pull away frm me still can't do it altho my shifting is ultra slow now due 2 double clutching..hehehehhehehe
idup VTEC!
n oh yeah...i once bought a set of synchros..3/4 if i remember correctly,frm LHS....d whole bunch of stuffs cost me almost RM700 wor?i can't remember consists of wat...my mechanic took out d faulty part...tied it up w sum wires..sent 2 LHS n told them 2 get me d whole bunch's replacement......
but din last me long either those new synchros..heheheheeh
king_jamez
551
Shoken7,
gearbox oil should be changed every 20 000km...2 yrs quite long unless u seldom use the car...
does anyone know whether these two items can really affect
performance? i know how they function but will it be worth it to
purchase them?
