YES, this is long, but its a good read.
While doing some research, I found a few articles that I thought would be nice to share with the community. There seems to be some confusion as to what "octane boosters" actually do and how much they really increase octane. This will hopefully clear some things up...
*note, the following article is from Australia*
Material courtesy of Fast Fours Magazine Nov/Dec 1999:
Octane boosters are popular in the performance scene because they often regain power last through detonation. Sold for around $25 in a handy bottle, they’re a convenient fuel additive and horsepower helper. But with so much brands on the market, you may be fooled into thinking they’re all as effective as each other. Which they’re not! Differing chemical compounds, additives and even volumes, mixed in with a good percentage of advertising, ‘independent" testing and testimonials all conspire to confuse the consumer away from the single most important paint: does it improve the octane rating?
Let’s see what’s worth it in octane boosters.
DO I NEED AN OCTANE BOOSTER?
The boys at "The Macquarie Library" describe detonation as: "Excessively rapid burning of the fuel mixture, often caused by auto-ignition due to excessive temperatures in the combustion chamber, incorrect ignition timing, lean mixtures, too high a compression ratio or unsuitable fuel," – as in too-low an octane rating.
Heard as a faint, metallic rattle, detonation is accompanied by a loss of power and can cause serious damage to piston crowns.
The significance of detonation is such that many companies produce fuel additives designed to increase the inherent octane rating of a given fuel. The proliferation of octane boosters has in part come about in recent times thanks to low quality Australian fuels. White or "Super" leaded fuel has been reduced from 98 to 95-96 octane, Premium Unleaded has also dropped to a minimum of 95 octane. And this presents a problem for high-performance cars designed to run on higher octane European or 100 octane Japanese fuel. Japanese import performance cars, Subaru’s STI WRX for example, runs an ECU program for 100 octane, but sometimes detonates on our Australian PULP.
All engines are different though and with Honda’s S2000 2.0-litre engine running a high 11.0:1 compression ratio, it relies on advanced engine management as much as quality fuel. But it can sustain its power on PULP. And of course any turbo owner who has experimented with boost will know if you run too much, it will detonate, so improving the octane is vital for maximum performance.
We must state that unless an engine is detonation through low RON fuel, octane boosters have little use. However, in a turbo or high compression application, the inclusion of a better grade of fuel allows the engine management system to optimize ignition timing and fueling.
THE CONTESTANTS
For this test we tracked down nine different makes and models of octane boosters, two fuel "additive," a straight race fuel and a drum of Toluene. Where there were several different "levels" of octane boosters in the one brand, we chose the strongest version.
The biggest claims the bottles have is the amount of "points" they claim to increase. This is ambiguous as a "point" can relate to either 1.0 RON (Research Octane Number) octane points, or 0.1RON octane points.
The list of entrants in our octane Olympics included:
STP Octane Booster
Wynns Octane 10+ Power Booster,
Amsoil Series 2000 Octane Boost,
Super 104+ Octane Booster,
VP C5 Fuel Additive,
ELF HTX 330 Racing Fuel Stabilizer,
Nulon Pro Strength Octane Booster,
PowerFuel Super Street Nitro Based,
PowerFuel Max Race Nitro Based,
NF Octane Booster Racing Formula,
NOS Octane Booster Racing Formula,
Toluene,
VP Motorsport 103 Unleaded Racing Fuel
THE TEST
To conduct these tests we contracted independent laboratory Intertek Testing Services, who would test our products on a knock engine.
We had to also find a base fuel to add our boosters to so we went to the closest public petrol station, a Shell on the outward-bound side of the Westgate Bridge in Melbourne.
Being a performance-based test, we chose premium unleaded fuel as this represents the most common high performance fuel (ie: if you start with regular unleaded, you’re wasting money!). We should add that "some" boosters would have improved the octane rating of regular unleaded proportionately more than our tests with PULP.
With a RON rating at a minimum of 95, we first established the exact octane of the PULP. The biggest surprise was our randomly select Shell resulted in a quite high 96-8 RON.
We precisely measured and mixed each additive to the PULP, according to each manufacturer’s recommendations and specs and poured each into the knock engine’s tank. The compression ratio was then slowly increased until it started to knock, gaining a threshold of detonation and subsequently a maximum RON rating.
Of less importance but still worth mentioning is the design of the bottles: since most people will be pouring it straight into a tank, the design of a bottle is important to prevent any spillage on paintwork causing damage.
So let’s look at the results!
THE RESULTS
BASELINE OCTANE 96.8
Octane points
It’s very easy to confuse octane ratings as there are a number of separate international standards. MON (Motor Octane Number) is the number derived from a fuel when it’s applied to a test engine run at 3000rpm rather than 600rpm and higher inlet temps and ignition advance. The Australian importer of 104+, Andrew Holdsworth, suggested MON is seen as a more real-world test.
Though none of the fuel companies promote the MON figure which is normally between 7 and 10 numbers less than RON (Research Octane Number).
Intertek’s Graeme Marks believes RON provides the general public with an idea of which additive works more effectively. And being the most commonly-used reference, we’ve used RON for all our tests.
THE CONTESTANTS
STP Octane Booster
Toluene,
THE TEST
THE RESULTS
Octane points
