Focal Subwoofer 30A1 12''
ICE -In Car Entertainment
vicconline
148
518
1))) Focal 30A1 Sub Woofer 12'' ((New WIth Box))
12" Focal Access Line 1 subwoofer
Magnet: 145mm
Voice coil: 50mm (2"), 4 layer
Power Handling: 250 watts RMS/500 peak
Impedance/voice coils: single 4 ohm
Freq. Resp.: 27Hz- 500Hz depending on load
COD KL OR POST
---------- Post added at 08:02 PM ---------- 6 hour anti-bump limit - Previous post was at 08:02 PM ----------
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Wts 1)))) DLS Ultimate Us6.2 6-1/2" 2-way Component System ((New WIth Box))
((((((Interest PM /SMS / CALL ME))))))))
010-2216379 kit
-cod kl cheras or post
Power Handling:
Peak: 160 watts per set / 80 watts each side
RMS: 100 watts per set / 50 watts each side
Aluminum cone body
Rubber surrounds
1" Silk dome tweeter
Ferrite magnet system
Die cast basket
Filterboxes with selectable tweeter level in four steps
Speaker grilles included
4 ohms impedance
2" Voice coil
Frequency Range: 50-25,000 Hz
Sensitivity: 91 dB
Crossover Point: 4000 Hz
Magnet Size: 4"
2))))) Focal 30A1 Sub Woofer 12'' ((New WIth Box))
Magnet: 145mm
Efficiency: 94dB (1W/1M)
010-2216379 kit
vicconline
148
518
010-2216379 kit
Power Handling:
Aluminum cone body
Rubber surrounds
Die cast basket
4 ohms impedance
2" Voice coil
Sensitivity: 91 dB
Magnet Size: 4"
Magnet: 145mm
010-2216379 kit
vicconline
148
518
010-2216379 kit
Power Handling:
Aluminum cone body
Rubber surrounds
Die cast basket
4 ohms impedance
2" Voice coil
Sensitivity: 91 dB
Magnet Size: 4"
Magnet: 145mm
010-2216379 kit.
vicconline
148
518
010-2216379 kit
Power Handling:
Aluminum cone body
Rubber surrounds
Die cast basket
4 ohms impedance
2" Voice coil
Sensitivity: 91 dB
Magnet Size: 4"
Magnet: 145mm
010-2216379 kit.
vicconline
148
518
Nego Nego Nego
010-2216379 kit
Power Handling:
Aluminum cone body
Rubber surrounds
Die cast basket
4 ohms impedance
2" Voice coil
Sensitivity: 91 dB
Magnet Size: 4"
Magnet: 145mm
010-2216379 kit
vicconline
148
518
Nego Nego Nego
010-2216379 kit
Power Handling:
Aluminum cone body
Rubber surrounds
Die cast basket
4 ohms impedance
2" Voice coil
Sensitivity: 91 dB
Magnet Size: 4"
Magnet: 145mm
010-2216379 kit
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
vicconline
148
518
Magnet: 145mm
COD KL OR POST
Hey guys,
I have a 4g93T under my hood and have had this lovely engine for nearly a couple of years now.Did no bother about installing any boost meter or whatever as i don't find the need too.stock standard.but suddenly got the urge to fix some gauges.what is the most important gauges for a stock baby.i'm sure boost meter will be the most important.what else comes next?oh yea i dont even have a timer.Oh if u guys can list down the gauges by importance it would be very helpful.if brands of...
