few stuff - 4g63 evo
4g63hks
178
hi fellas....
as mention above :-
evo 3 ecu - RM 850
evo 3 ecu , wiring (no air flow sensor) - RM 1250
throtle body e3 ( 2 set) - RM 350
injector evo 3 ( 2 set ) - sold out
evo head (complete cam,valve,spring n pnp at japan) - RM 450
piston evo ( 2 set) - RM 300
evo twin pot front disk ( 2 set) - RM 400
rear evo disc brake - 650
mivec rear disc brak - 600
evo 4wd fuel tank - 350
evo 3 intercooler - sold
complete set evo door together with cromax mirror (exclude door panel)- 500
autoflip side mirror (complete wiring, switch n realy ) - 250
ogura clutch super single for CA18 - 900
HKS adjustable hi/low for SV4 - 1300
all item are negotiate till sold
plz call man 016 4590106
exedy racing clutch 9" with clutch cover - used 6 mth RM 650 (013 2174230)
4g63hks
178
bro,, plz call,,
the best price deal by phone,, seldomly online here
btw, if i set the best price here,, still people negotiate the price but didnt take it at all
serius buyer secured...need to clear all the stuff
Bump....
4g63hks
178
new item added,
ngk power cable 9mm for evo - 180
wiring engine n dashboard + ecu + air flow for vr4 (used on wira) - 600
Nismo double plate clutch for skyline - ono
NEGOTIABLE
plz call me asap 016 4590106
hello all,
i got the GAB SS series adjustables for my vios. so, i will be spending time tweaking it! however, some queries below:
1. my front spring rate is 6kg and my rear is 4kg. with my damping set to hard, the car is bumpy, but in corners, slight body roll is noted. should i up my spring rate to further reduce body roll, or is slight roll acceptable? I have thought of installing anti-roll bar to the rear, but was advised not to do so as it may distort the suspension from doing its...
