FD 4.785 Questions..!!!!
toya_flywheel
to all Otai2 outside there..i hv a fews question..hopefully u all guys can gv me the best answer..tq
civic A > B16A + PnP + type R camshaft (complete wif type R valve & spring)
civic B > B16A + PnP + gearbox b18cR wif FD 4.785
civic C > B16A + PnP + type R piston
which one is better for 400 meter.??? can B tapau A & C..?..tq..im still new..hope i can hv positive answer..tq..tq..tq..
shiroitenshi
3,676
170
That is vague question.. depends on the torque the engine makes and how much rpm it can pull.
If one of those B16As can somehow make more torque (at wheel) at 6-8K than others at 7-9K rpm with 4.785, it can be an upset.
But B16A will feel lighter with a gearbox with 4.785 for sure.
evoX2
1,167
KCH
agree with shiro, but i would guess either A or B. It also depend on the launch skill, traction etc....
budin99
429
waaa....inchey toya_flywheel..demmm serious you aaa..until here looking for 4.785 info keh keh keh....
Those "A" car sudah siap ka? ready for charity run?
and those "C" need insurans wooo ekekke
eddie_vtec
545
aiyo...very hard to know...
if by rpm n kmh..how to check?noob here....
E-Tech
1,115
256
3,183
Johor
Wanted to attach my excel file for gearing calculation... but post do not accept excel file.... so you can only see in word but cannot use lor....
If you know the gear and rpm and speed, can guess if the car has changed the FD...
If the gear box on the floor , can put into 1,2,3,4 gear and turn the clutch turns versus 1 complete drive shaft turn...
Just my 2 cents...
shiroitenshi
3,676
170
Hehe.. Mine is no where so complex as gearcalc, but shows most of the information required.. this is the revised edition since the last one I posted last year. A few additions since then.
You need to know how to interpret the chart though, but I guess most can guess after they play with it a while.
I think E-tech will find it very fun to play with. Nice work with yours, but speed loss from playing with gears not apparent there, nor does how shifting one ratio affects the next gear.
So far, I've done up to getting estimations of rev drop per shift, tire expansion correction (I am still trying to make a fully scaling tire expansion correction, but currently no way to measure them in real life yet.)
XLS in zip file. This is actually a portion of the complete worksheet.
hi all,
just asking on my current Hks Eids that i just installed two days back....
no matter how i adjust the two knobs i still can't get it right, sometimes even worse that it stalls the vehicle after blow off, i'm suspecting something's wrong with my current stock ISC / servo motor, could they be the reason? went to a workshop that day who has access to MUT computer n according to him my stepper motor isn't fully 100% good....
the prob is even during idling, when i step and...
