evo 9 fuel consumption
Jun_EK9
1,328
67
im using pfc and the tuner was a ex rally technical person
---------- Post added at 04:11 PM ---------- 6 hour anti-bump limit - Previous post was at 04:05 PM ----------
another info is make sure u use the correct engine oil, no leak in ic piping ,or turbo failure ( fin is gone or shaft is loose)
5speed n 6 speed is diff in Fc too
I thought 6 speed close ratio saja?....:hmmmm:
p3jal
1,493
183
Selangor
jun_ek9 is my sifu..he very good person. and humble...wow..my car more better then ts car.hhehehehe...mine can go 270km if fuel tank..ok end of this year i wanna masuk Std alone ecu.
vspec
Rookie
345
74
Tehran
6sp 3000 rpm 120kmp
5spd 3000 rpm 100 kmp
sifu Jun_EK9, my car is 5 speed but 3000 rpm i can get around 120 km/j. problem with something i guest? :hmmmm:
evojinx
29
13
1,503
my e8 can go up to 300km with heavy foot. about 350km if driving around town.
low boost 1.3bar & high boost 1.6bar.
nvr try ron95 before. my car has been pampered with ron 97 since day 1 :)
ehdrian
I Don't Care!
3,310
280
1,683
Wow! that is bad. I remember when raise my fuel return to 3 bar, I get 280km per tank which is still better. Set back to normal, getting 320km per tank....[/QUOTE]
bro, u mean u set the fpr to 3bar?..mine currently 3.5bar, fc quite bad.
yup, taken the gadget out and using the car normal one now. Why I took out is because even though higher FC, but did not feel any power gain....
ehdrian
I Don't Care!
3,310
280
1,683
Then wats yr highest boost using the stock regulator?
ehdrian
I Don't Care!
3,310
280
1,683
1bar shud be no prob, i accidentally boost 1.5bar before, the car got no ems, just fpr..luckily din kaboom..
Hi all, my car windscreen I 'pandai-pandai' use some 'anti-water mark' solution to clean, now a bit misty already, but the other side and rear window now very shiny and smooth.
So problem only on my front windscreen, I would like to have a glossy finish, can I use autosol and polish it? Please advise, thanks.
