Engine Vibrate! Need Help!
vastalux
180
When I switch on the engine the car starts vibrate and as result steering, cabin at back seat, front hood and front light vibrates too!! Same result I can get if change transmission from Neutral to Drive and press break to prevent car moving. If I switch conditioner on the car "shaking" looks like massage chair.:bawling:
I do not have any vibration when engine RPM greater then 1500.:hmmmm:
Note: I changed spark plugs, spark plug wires, air filter, cleaned MAF, throttle body and decarbonized. Plan to buy "Energy Mount Insert" for engine mounting which i do not know it will help or not. :hmmmm:
Anybody know what going on with that car? Please share your valuable advise and experienced.:adore:
TQ
jlaudio12w3
Most probably ur engine mounts have worn out. Inserts will help to reduce engine rocks n give sum better feeling on throttle...
vastalux
180
ic2..so is it help reduce my car vibration by using "Inserts"? or I still need to buy new engine mounts?
jlaudio12w3
Hi LCK, If it is your mountings kaput, u need new mounts. But since u have bought the front and rear inserts, unless the front n rear mounts totally worn out, only u need to change and put the inserts in. But if they are slightly compressed, you are still able to press the inserts in. You can change the side mountings. The driver side mount tend to wear out fast... The mounting inserts help to reduce wheel hop n engine rock. You won't regret getting them...
vastalux
180
TQ jlaudio12w3..you r so convincing. :adore:
i try use the mount insert first then see hows the result. if vibration still there, then my last resort is changing the engine mounts. :bawling:
jlaudio12w3
No problem LCK. because once u use the inserts, no point wasting the cash on the front n rear mounts. Just get the side mounts n spend your cash on other items.. Enjoy..:driver:
Barbarian
625
24
www.myjsoc.com
why would you wan the inserts????? change your mountings and that will do the trick... inserts is for hard core drivers... you will have more vibration with the inserts compare to new stock mountings only......
vastalux
180
i was made understand that insert can reduce vibration for old engine mounting. now look like i misunderstood.:mad:
Barb, since you mentioned it will have more vibration with the inserts compare to new stock mountings and my car only vibrate badly if rpm below 1500 so will i experience more worst vibration? am i rite or not?:bawling:
---------- Post added at 06:01 PM ---------- 6 hour anti-bump limit - Previous post was at 05:53 PM ----------
TQ jlaudio12w3...
look like your experienced on this Insert different with Barb..:hmmmm:
Hopefully it works as per expectation...:driver:
Barbarian
625
24
www.myjsoc.com
if you wan a comfortable ride then dun put the inserts... if you wan a more sporty feel with fast gear change response then go ahead...... the inserts main purpose is to protect the gear box!! reduce wheel hop significantly(if you have enough power to hop)......
The Marketplace Top Posts
HI guys!!
I've just changed my Crank pulley to a Aluminum after market used one on to my 4AGE blacktop, and had all the belts changed as well, ,,the thing is, everytime i jump into my car and drive it for about 5 minutes or so, my belts starts to make this horrible squeaking noise. tried tightening it and lubing it up with abit of silicone spray, helped for about 2 days,,,after that the nosie started to return...aggghh
seeking help!!
thanks!!
