Engine swap for bmw e36?
arielhow
12
Hi all,
I can't help but wonder if I should really consider doing a swap for my 318 e36. You guys prolly would already know it is underpowered. It only gives decent amount of power only if 1 or 2 ppl are in the car. Any amount of ppl more than that...well, let's just say it is not ideal and offers only bad FC at the end of the day. So here're the two questions of the day for you masters of the road out there: Is it wise to swap it to a bigger bimmer engine like a 2.5 or 2.8? How much would the WHOLE process be?
Thanks! :biggrin:
5115
Nobody
5,952
2,254
a conversion to 2.5 auto would cost you min 8k-10k,included halfcut,labour,parts & oils.
gwumpkus
39
4
1,508
Singapore
u may as well do the 2.8ltr... marginal difference..:)..
that said, the 318i is ok a runner i feel... i get about 10km/ltr from both of mine... considering the 2.8ltr transplant for one of them.. but that project is put on hold, the Supra gets my attention for now..:)..
is your 318i the M40? or M42?
5115
Nobody
5,952
2,254
you mean M40 & M43?M42 is twin cam,similar output with M50B20 2.0
arielhow
12
It's a m43 engine. Hrmm, 8k-10k ey...some friends suggested superchargers, would that be advicable? and i think it's pretty hard to find a 2.5 auto engine these days,no?
arielhow
12
I did, but sadly the engine you showed me was not available anymore so i stopped hunting for awhile. Now i'm kinda itching =P so minimum 10k to do a conversion? and no to supercharger?
arielhow
12
SWEET!
I think it'd still be ideal to just swap to a m42, considering that i don't need to change much of the car cept the wiring? correct me if i'm wrong but swapping to a 2.5 or 2.8 requires me to change the wheel mount as well or something like that due to the weight of the engine etc?
Sonic Thunder
333
8
bro...swap in da F20C from da S200 sr8 man!
ive seen a E36 on option video b4!
V-TEC POWER!:burnout:
jst my opinion!
g'luck wit ur conversion!
cheers!
ehdrian
I Don't Care!
3,310
280
1,683
Penang
wat abt RB25/26?..sounds good with lotsa hp?..
gwumpkus
39
4
1,508
Singapore
my friend's just done the M42 swap into his 318i, seems to be straightforward job... :) so far the only s/c ones i know are some chaps in the US, who've used the DASC into the m44's..both for Z3s and 318iS..
wheel mounts? er.. u mean the hubs etc? never thought they were an issue..correct me if i'm wrong, but the chassis is pretty much designed to take all the engines, of course mountings might differ, but mounting positions are afaik same.
seems manual versions are diff to find..so if u do find a 325/328i that u want, u could do the transplant, ensure everything is runnig stable, before u swap out the autobox.. also a straightforward job..depends on what engine u get, i might have a spare getrag 5-spd lying around from our "spares"..:)..
good luck bro..:)
SWEET!
arielhow
12
Thanks for all the suggestions bros :) I'm kinda determined to just swap it to a bimmer engine, ideally a 2.5/2.8 auto. Any reliable cut-shops that any of you may know of or reccomend?
@gwumpkus, how did your friend find the difference after the swap? was it worth it and how much did it cost him overall?
The Marketplace Top Posts
Posting on behalf of my friend.
His Civic B20 VTEC idling sound. He says the car doesn't sound right but doesn't know what's wrong. He even does not know if there is really a problem. Just listen to the sound, He brought his camera as close as he could to capture the sound, so nothing much can be seen. Please comment if you think you know what's the problem. Thanks.
Again ignore this crap video. Just listen to the sound. Hehe.
Does...
