M M-Power-3 Junior Member Senior Member Joined Oct 8, 2005 Messages 18 Points 1,501 Oct 22, 2005 #1 Need Help On Something Any piggyback that can thow away the need of Air Flow Sensor? My car BMW 318 E36
A Ali_G Known Member Senior Member Joined Nov 15, 2003 Messages 343 Points 3,018 Location K.lumpur Oct 23, 2005 #2 Mircotech piggyback.
Temujin 1,000 RPM Senior Member Joined Nov 5, 2004 Messages 1,474 Points 5,213 Location Selangor Oct 25, 2005 #3 rps13? heheh.. goin m power now eh.. e-manage cud go air flow less.. but then not sure if contis can be done..
T taqu Known Member Senior Member Joined Dec 17, 2004 Messages 207 Points 3,018 Oct 25, 2005 #4 Why do u need to remove the Airflow sensor? Do u mod the engine?
Mazdaspeed A-spec. 500 RPM Senior Member Joined Apr 11, 2004 Messages 587 Points 3,016 Location Petaling Jaya Oct 25, 2005 #5 e-manage ultimate f-con v pro power fc HKS vein pressure converter remove maf to eliminate bottleneck/ restriction of airflow you will need a map sensor to remove maf Last edited: Oct 27, 2005
A alvin24 3,000 RPM Senior Member Joined Nov 14, 2003 Messages 3,113 Points 5,148 Oct 25, 2005 #6 only standalone engine management can do such things... piggy back ECUs rely on OEM sensors.
