Brand New. Intercooler Hoses.
The ELEVO® Silicone Hoses provide a unique opportunity to upgrade your engine hoses to a product that is simply reliable & affordable for performance and looks. With many sizes for the most popular cars, these direct replacement silicone hoses are available in striking blue to blend with your engine.
The ELEVO® Silicone Hoses are designed to replace original equipment for a wide range of applications. Superb integrity and superior performance reduce the risk of component failure and that enables higher temperatures (up to 200°C) and pressures to be maintained with complete confidence.
*Standard silicone hoses are not suitable for carrying high pressure fuel/oil lines.
Features:
1. Heat resistance. (will not be harden due to under extreme engine compartment heat)
2. Pressure in intercooler piping is maintained.
3. Available in many sizes for custom applications.
4. Affordable pricing.
5. Will not "pop out "of intercooler pipings like stock rubber hoses. (provided it is installed correctly)
Price List:
ELV-ECH-35MM Straight Coupling Hose 1.38" $ 40.00 (mostly used for blow off valves) ie. SARD/HKS SSQV
ELV-ECH-45MM Straight Coupling Hose 1.75" $ 40.00
ELV-ECH-51MM Straight Coupling Hose 2.10" $ 45.00
ELV-ECH-63MM Straight Coupling Hose 2.50" $ 50.00
ELV-ECH-76MM Straight Coupling Hose 3.00" $ 50.00
ELV-ECH-89MM Straight Coupling Hose 3.50" $ 55.00
ELV-EHH-50MM Coupling Hump Hose 2.00" $ 81.00
ELV-EHH-60MM Coupling Hump Hose 2.30" $ 99.00
ELV-EHH-70MM Coupling Hump Hose 2.60" $ 99.00
ELV-EHH-80MM Coupling Hump Hose 3.10" $ 99.00
ELV-ESR38-51MM Reducer Hose 1.50" to 2.00" $ 77.00
ELV-ESR45-63MM Reducer Hose 1.75" to 2.50" $ 77.00
ELV-ESR51-63MM Reducer Hose 2.00" to 2.50" $ 77.00
ELV-ESR63-76MM Reducer Hose 2.50" to 3.00" $ 88.00
ELV-ESR76-89MM Reducer Hose 3.00" to 3.50" $ 90.00
ELV-E45 - 45MM Elbow Hose 45° 1.75" $ 99.00 (new pricing for elbow hoses)
ELV-E45 - 51MM Elbow Hose 45° 2.10" $ 99.00
ELV-E45 - 60MM Elbow Hose 45° 2.38" $ 118.00
ELV-E45 - 70MM Elbow Hose 45° 2.60" $ 118.00
ELV-E90 - 45MM Elbow Hose 90° 1.75" $ 99.00
ELV-E90 - 51MM Elbow Hose 90° 2.10" $ 99.00
ELV-E90 - 54MM Elbow Hose 90° 2.13" $ 99.00
ELV-E90 - 57MM Elbow Hose 90° 2.25" $ 99.00
ELV-E90 - 60MM Elbow Hose 90° 2.38" $ 118.00
ELV-E90 - 63MM Elbow Hose 90° 2.50" $ 118.00
ELV-E90 - 76MM Elbow Hose 90° 3.00" $ 128.00
3SH-20KG-BUVacuum / Boost 3MM $ 19.00 per meter
6SH-20KG-BUVacuum / Boost 6MM $ 27.00 per meter
9SH-20KG-BUVacuum / Boost 9MM $ 38.00 per meter
(10% discount for above 2 meters in a single purchase for vacuum hose)
Interested Buyers please email [email protected]
Tel: 016-4786000
Silicone Hoses Tech Tips.
1. To Cut - use a new 'snap Off' blade in your knife. Tighten a jubilee clip around the hose and use the edge of the clip as a guide for the knife blade then slip off clip and slice through the remainder with the hose resting firmly on a flat surface.
2. To Clean - use hot soapy water. ( Do not use Gasoline or Chemicals )
3. To Fit - always use good quality hose clamps with silicone, ones with rolled or bevelled edges and a smooth liner…never use clamps that have the drive mechanism perforating the inside of the clip.
Features:
Price List:
Tel: 016-4786000
