I need to replace my front rotor due to crack. I notice it 2 days ago while changing adsorber. Can anyone suggest a good rotor n where can i get it. This time i planning to use slotted rotor, my PCD 100 with 4 screw.
I have a 1600cc 20v and i would like to know of any other modification that can be done to it. As it stands it already has on extractors it has a slivertop half and a blacktop bottom half with blacktop throttle bodies a 10lb flywheel it also has a switch inside that i can switch to sorta like advance the value timing i not sure what pistons i am using but i have a standard 20v clutch but i just tell myself and it can do better because right now in my country the TOYOTA RUNX 1800cc 20v is...
