Hi all ,
i just want to check with all the sifus out there regarding the LEDs on the Emanage itself..
there is one , the interaction LED which will blink orange when u are driving..
another one is the Active LED, which will blink red if there's a fault code....
for the Active LED, lets say everything is OK ... should it be blinking GREEN or should it be SOLID green(not blinking)
after Dyno setting my car,(means set with Laptop) it was Solid Green, but now i tried twitching the 5 AAV points (to increase fuel) the active LED wont stop blinking Green, means it would never change back to SOLID unless i set it back to 0% .... (original location)
I did that becoz after checking my plugs, it was really WHITE !
1 more thing is that , if u unplug the emanage and plug your car back with the standard ECU...... run a few days and then plug it back to emanage... will this mess up your Emanage settings and so on ....
need your expertise feedback .... tried searching around the manuals and websites..... they didn't have any clear explanations regarding the blinking or solid..... but as far as i know .. green= good..... red= u are fu*k3d
