Dynatek ARC-2 ignition Booster
andysky5
33,386
55
1,648
Dynatek has introduced the ARC-2 for 4 cylinder Motorcycle applications. This CDI ignition is capable of producing over 50, 000 Volts at the spark plug, and has the highest spark energy of any CDI on the market. It is designed to optimize the ignition of the modified vehicles, providing the strong spark needed to develop peak power for turbocharged, nitrous oxide and high compression applications.
Intelligent Spark Profiling in the restrike mode allows for less delay between successive sparks. It also features a built in launch limiter for drag style launches as well as a built in retard mode. The lightweight and compact ignition will be offered in plug in kits for select motorcycles & automotive models that will make installation a breeze, with no need to cut into the stock harness. For other models, a universal install kit is available.
ARC-2 Features
Smallest Ligthest CDI on the market
Over 189mJ delivered to the coil per spark, the highest of any other on the market
Over 500V to the coil primary
Over 50kV to the coil secondary (assuming a 100:1 coil)
Intelligent Spark Profiling (ISP) allows for less delay Suzuki between successive sparks
Spark Restrike up to 4500 RPM
Provides this high level of output from as low as 8 Volts from the battery
Works with any 2 coil OEM ignition, with or without fac ignitor (some systems may require replacement coils)
Built in launch limiter, works from 2000-11900 RPM
Built in fixed timing retard function
Tach output
ARC-2 Technical Specifications
Operating Voltage: 8-20 Volts
Operating Current: 7.0A @ 10, 000 RPM
Maximum Operational RPM: 18, 000+ RPM
Ignition Inputs: 2 Rising or Falling Edge
Ignition Outputs: 2 Independent Channels
Coil Primary Energy Max: 189+ mJ
Coil Primary Voltage Max: 500+ V
Restrike Window: 25 Cranksahft Degrees
Launch Limiter Input: Single wire, ground to activate launch limit
Retard Input: Single wire, ground to activate timing retard
Tach Output: 12V square wave, 50% duty cycle
Dimensions: 4" x 4.6" x 1.4"
Weight: <1.25 lb
**Harness for Mitsubishi and Proton 4g9x
for more information click on this link Dynatek - Sportbikes Arc-2
Price : rm1380
Interested pls. pm or call : 017-3526055 (andy)
Dealing method : COD at Rev Performance @ No.7, Jln PJS 11/24, Bandar Sunway (1st Floor, on top of F3 Racing) or Send by Postlaju.
Operating Hours : Monday to Saturday ( 11am - 7pm )
CLICK HERE to check out my other sales Item !! :burnout:
gtm_maxwell
112
Can this items use with COP ( Coil On top, after market coil for EVO 3? Spark tech ) ? any adjustment needed?
The Marketplace Top Posts
hallo guys...wanna ask you guys...why a...if u wanna buy racing camshaft u need to trade your ori cam with cam that u wanna buy....is it they use da ori cam to built da racing cam oo what???:smokin:
