Dvvt Engine with APEXi VAFC
Dvivat
hello sifus...can APEXi VAFC install to Perodua DVVT engine??
comment pls...tq..
xtremeleo
3,247
464
can, but not useful. VAFC cannot control the dvvt pulley, u need sumthing else for dat. safc wud be enough, an emanage wud be better
ar rai
25
For standard DVVT engine.Is it worth to install emanage first..then add some lighten pulley,throttle body,bigger piston??
sorry i'm newbie here..
cybs_mv
conclusion is not suitable ma? coz i juz got 1 v-afc and plan to use it on my myvi.. all sifu pls teach me and where to do installation and how to set it? tq tq tq
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
many shop in Sunway will help u out...
DJgErM
4,014
118
SIC Turn 7 & 8
www.germ.cjb.net
places like Excool..
but DVVT isn't supported by VAFC...it works differently..
what we can do with DVVT engines is to only fiddle with the AF ratio and ignition timing...even with the timing...its either advancing it by 1 or 2 nia...after that the knocking comes..
apeq89
171
5
sorry for digging up an old thread..
i m using auto 1.3 myvi..
mod that i've done so far:
dsport full exhaust system, K&N drop in with CAI, iridium SP, myth LCP, Pivot VS+GC..
and a few weeks ago i just installed emanage blue with dyno tune at N1 racing..
without emanage i got 81.45ps(N1 dyno jet machine) with 11.10kgm torque/ 78.5whp (millenium dyno dynamics machine)..
after putting on emanage with dyno tune, i gain 8ps which is up to 89.80ps but only 0.41 gain in torque, which is 11.41 kgm..from the dyno chart that i got from N1, Desmond starting the tune point from 4.7k rpm with 13+ AFR until 6.7k rpm..before 4.7k rpm, my AFR all arround 14-15..at this point (from 4.7k rpm) also the PS started to gain quite a lot, but only a minor increment in torque..
my question is, is that possible to tune the AFR again at a lower rpm point to increase some torque?
because, currently i didnt feel any improvement after installing e-manage unless i rev hard (more than 5k rpm) but its only a little feel..
cybs_mv
mayb setting problem.. If i m wrong pls correct me.. Biasa i c magazine, mod v open pod filter+ apexi safc 2+ full set exhaust without e-manage can gain ard 10+hp jo.. Urs v emanage y so low?
---------- Post added at 05:09 PM ---------- Previous post was at 04:48 PM ----------
Latest Offer!!!! Ecu Tuning For Mit.airtrek ..... To Remove Speed Cut Only rm 288...... Second Stage Tuning Remove Speed Cut, Boost Cut, Rev Cut Only rm388,.....and For First Stage Remaping Including Of Remove Speed Cut,boost Cut,rev Cut, Air/fuel Map Tuning Only Rm 788 .....second Stage Remaping Including Fo Remove Speed Cut, Boost Cut,rev Cut, Air/fuel Map Tuning,boost Tuning,ignition Tuning Only rm 988 .. Limiter Time Only........pls...
