Diy : Undercarriage Lights
youmolo
208
Subang Perdana
www.tzywen.com
resilienthunter said:
yo ppl..
khor : yo bro..i've done up my ICE in my car.. and i realised that got sum interference when i switch on the lights..what should i do huh?
youmolo : ur the guy in cardomain right?
edmx : black with pink is P.I.M.P.I.N ! mus show pics ok!
i suggest u put a filter when connecting the chokes. mite b putting static noises into the 12v line.
yea, i am =) tht page is done by my bro
koren
148
How to wire the ballast to the original boot lights ar? can i just do this?
frcgrey
196
selangor
hey bro,
yes,you're right....that's the way.but remember connect a fuse between incoming and outgoing wire...in case any wiring problem.
good luck.
Hi Folks,
After 2 years of running my E46ci with unoptimized 1JZGTE VVTI, i picked up an Edamage Blue which i had for several years to hook it up. As expected, used ECU always had problems, my ignition harness is not readable but the rest of it works fine. Initial runs started with 235 whp/ 315nm wtq at 5.2k RPM. A few more runs and we achieved 251 whp / 320 nm wtq at 5.1k RPM. I am not sure whether this is a healthy result of 1JZGTE VVTI, considering factory declared crank HP is at 276hp...
