Cusco brand is good, but I heard its for competitive driving oriented, so it can be a bit hard for public road driving, esp malaysia road. GAB brand not sure.
Anyway, i advice members try not to buy springs/absorber from kedai potong. They are cheaper but they are (mostly) defective or close to expiration and needed service.
evo's body is harder n heavier. if wit tat settin in ur wira sure is a lil bit over, thn u dun hav think bout comfy feelin as it wil b a solid rod like. i put in a 1.8 spring in2 my 1.5 edi make me suffer. wat they said r rite as malaysian road conditon is reali bad. wit tat kind of harder settin ur car may not hold on da road wel or even worse thn ur ori stock suspension.
handlin is not achieve wit hard settin suspension but oso hav 2 consider da road condition, tyres, chassis n ur requirement.
if u said it's for evo,u will feel bumpy.first of all,evo weight 1++kg more then wira.sec,it design
for 4wd car to eliminate squat when the car accelerate meaning if u install on ur car,u will feel
hard at the rear.
i'm also exprience using cusco on wira 1.6, not really bad, sometimes when i press the throttle, power come as i want, like it when speed over 100km not like "sampan"...
But too bumpy when drive slowly..now change to standard one..:proud:
dun waste u time go for cusco...make sure zero2 coilover one...not the big shaft.
it comes wif adjuster at the body no only the spring palce can be adjusted...sure u
wont regret...forget bout comfort when u chose perfomance part bro..
I thought this would be the PERFECT test car for the Castrol Edge as being an old car, this will really test out its protective properties. Also, it’s a heavy car with a 2.8cc engine so fuel consumption is generally on the high side. Since owning the car in December 2009, it’s been running on an average 6.3 – 6.4km per litre of fuel. It’s on a strict diet of RON95, being my daily drive and the ever rising cost...
