I bought a set of crystal headlamp from HMS and fitted it with HID kit.. the bulb fit nicely and not touching the cap..Supachip said:Then anyone knows how am I suppose to install the HID bulbs?
In addition, I am using the wira black crystal headlamp as those sell by HMS.
Anyone please shed some light on this. Thanks!
Yup...me too...i had remove the cap.It even sharper then before.The light focus brighter on the road and the focus is more wide.Just make sure the setting of ur headlight is perfect and not disturbing other incoming user.(the headlamp can be adjust rite..)heefmy said:i had remove the cap but nothing effect, even the light focus more wide, for those who use crystal light(wira) can take out the cap.
wont get any disturbon for other user.
Have your headlamps adjusted to the correct angle and it should be shining at the correct distance.calvin9683 said:i'm also using black base crystal light....
find it hard to adjust the light...sigh...mayb i'm not good at it....
still driving wif light not shining far enough...thats dangerous...
i'm using normal bulbs....izzit true that removing the cap will cause the light to be brighter??...but then will it look uglier coz ppl can see ur bulb directly...where as wif the cap...i personally think it looks good...
is there any easy way to adjust the light??
