Carrozzeria,Alpine,Kenwood, Addzest & More ICE Item!! UPDATE!!!! New Arriva!!!
Dear ZTH Forumers & Guest
I've some ICE goodies imported from Japan WTS. Thanks for viewing...Arigato!!!
Payment Type: COD or ATM Deposit
Shipping method: Poslaju
Contact No: 012-2398974
For more JDM ICE Item, Click here ---> Lazy Crazy Site!!!
*Price is fixed and nett
*Buyer is allowed to test the item first before buy during COD
Serious buyer only to contact Man@012-2398974 (*No SMS plz!!! Call for faster deal)
Alpine PXA-H701, DDDrive Component And Woofer, V12 Amp
Hi all, I would like to sell the following item as per package below. Details and specification for each item as listed below.
Package 1
Item : Alpine PXA-H701
Price : RM1600 nett
Package 2
Item : Alpine PXA-H701 + RUX-C701
Price : RM2400 nett
Package 3
Item :
1) Alpine PXA-H701 + RUX-C701
2) Monster RCA Cable 101 XLN Xtra Low Noise (3metre lenght)
3) Monster STANDARD Interlink Junior RCA Cable ( 5metre Lenght)
4) Audio Technica JAPAN RCA Cable ( 3metre Lenght )
4) Lightning Audio Power/Ground Cable 8AWG, 735 Strands, High Performance OFC (4.8metre)
5) HeliX Baby Cap Noise Supressor for Generators
6) Mic for PXA-H701 ( For Auto Time Alignment Purpose)
Price : RM3000nett
Package 4
Item :
7) Alpine DD Drive Component Set
Price : RM4000nett
Package 5
Item :
8) Alpine DD Linear Satellite Speaker
Price : RM4500nett
Package 6
9) Alpine DDDrive 12inch Subwoofer
Price : RM5000nett
Specification
Alpine PXA-H701
# mobile surround sound processor
# decodes 5.1 Dolby Digital and DTS signals
# Dolby Pro Logic II (applies multichannel processing to stereo sources)
# three optical digital inputs
# front, rear, center, and subwoofer preamp outputs
# two RCA audio inputs
# navigation sound input
# Ai-Net input for connecting a compatible Alpine component such as a DVD player
# Alpine CD changer input
# digital time alignment for optimizing the sound in specific listening positions
# graphic equalizer — 31 bands for front, rear, and center; 10 bands for subwoofer
# 7-band parametric equalizer
# active crossover system maximizes speaker performance
# MediaXpander adds fullness to your sound
# 3-step bass compensation
# phantom center channel simulates center effects if no speaker is present
Helix Baby Cap
- Suitable in order to prevent disturbances of the generator
- Noise Supressor for Generators
- 33,000 uF
- Umax = 30V
- -55Celcius - +105Celcius
- Original Made in Germany
Alpine DDDrive Component
- Model : DDC-F17C
- Impedance 4ohms
- Frequency Response 35 - 35,000 Hz
- Sensitivity 90dB/W (1M)
1 Pair Midbass ( 200watts Max, 50RMS)
1 pair DDDrive Biodyna Dome Tweeter
1 Pair Passive Crossover
Model : DDW-F30A
Weight : 5.9Kg
- 600watts Max, 200RMS
- Dual Gap Direct Drive Magnet Design
- Neodymium Magnet
- Brass Voice Coil Bobbin
- 2 1/2" Diameter Voice Coil
- OFC Edge Wound Voice Coil
- One Peice Inverted Dome COne
- Hybrid MICA Poly Injected COne
- Push Pull Damper System
- Dual Spider Suspension
- Diecast Aluminium Magnet Heat Sink
- Extended And Vented Pole
- Aluminium Die Cast Frame
- Rubber Sorround
- Large Gold Plated Screw Terminal
PXA-H701 + RUX-C701
PXA-H701 + RUX-C701, Monster Cable, Audio Technica Cable And Helix Baby Cap 33
Monster Cable, Audio Technica Cable And Helix Baby Cap 33, Lightning Audio Power Cable
Audio Technica (3meter)
Mic for PXA-H701 ( Auto Time Alignment _
Complete Set Picture
Serious buyer only to contact Man@012-2398974 (Call Only, No SMS plz!)
*Preferable call me after 6pm as I'm working and may not be able to answer phone all the time
*All item sold as per package listed only!!!
* If you need any extra picture do let me know as I will upload it or MMS to you but only for serious buyer!!!
Alpine Phantom Face 7998R Copper Chasis
One of Alpine Flagship Model!!!!
This Unit Original Made In Japan!!!
Best SQ Deck from ALpine
Item still inside my card for buyer to audit.
All in excellent working condition except the screen need servicing
Price : RM1200
Picture :
Carrozzeria 6.5inch Midrange Speaker
Model : TS-C016A
Spec : 170watts Max, 45watts Nominal, Impedance 4ohms
Price : RM100
Carrozzeria 6.5inch Midbass Speaker
Model : TS-C160AII
Spec : 150watts MAx, 40watts Nominal, Impedance 4ohms
ORIGINAL MADE IN JAPAN!!!
Price : RM100
Alpine 2way 4inch Speaker System
Model : STE-102J
Spec : 80watts Peak, 20watts Nominal, Impedance 4ohms
Price : RM80
Alpine 5inch 3way Speaker
Model : STE-123A
Price : RM80
Alpine 4inch 2way Speaker System
Model : STE-100C
Spec : 100watts peak, 20watts RMS, Impedance 4ohms
Price : RM80
Alpine Subwoofer with box!!!
Model : SWS-1042D
Spec :
# 10" subwoofer with dual 4-ohm voice coils
# Kevlar®-reinforced pulp cone with aluminum finish
# 3/4" Santoprene rubber surround
# stamped steel basket
# frequency response: 30-1,000 Hz
# power range: 50-300 watts RMS (150 watts per coil)
# peak power handling: 900 watts
# sensitivity: 85 dB
Price : RM500
Alpine PXA-H701 Proccessor!!!
Spec :
# Mobile surround sound processor
# Decodes 5.1 Dolby Digital and DTS signals
# Dolby Pro Logic II - multichannel processing to stereo sources
# 3 optical digital inputs
# 8 preamp outputs: Front 1 (full range tweeters), Front 2, rear, center/selectable subwoofer and mono subwoofer
# 2 RCA audio inputs
# Navigation sound input
# Graphic equalizer
# MediaXpander
Price : RM1400
Alpine V12 2channel Amplifier
Model : MRV-T407
Spec :
# 2/1 Channel Operation
# Adjustable Crossover (LP)
# Auto Overcurrent Protection
# Bass EQ Circuit
# Bass Engine Ready
# DC Straight Design
# DC-DC PWM Power Supply
# Discrete Pre-Amp Stage
# Gold Plated RCA Input Connectors
# Input Mode Selector Switch
# MOSFET Final Outputs
# MOSFET Power Supply
# MultiMode
# Noise Elimination Coil
# One side Terminal Layout
# Phase Selector
# STAR Circuitry
# Solid Copper Bus Bars
# Speaker Level Inputs
# Subsonic Filter
# Top Mounted LED Power Indicator
* Dividing Network : 50Hz-200Hz HP/LP (12dB/oct)
* Foot Print (WxHxD)in : 7-1/8O x 11O x 2-3/8O
* Foot Print (WxHxD)mm : 180mm x 280mm x 60mm
* Frequency Reponse : 10Hz - 50kHz (+0, - 1dB)
* Heat Sink (WxHxD)in : 7-1/8O x 10-1/4O x 2-3/8O
* Heat Sink (WxHxD)mm : 180mm x 260mm x 60mm
* Input Impedance : 10k ohm
* Input Sensitivity (for rated power) : 200mV ~ 4.0V
* Power Requirements : 14.4V DC (11V to 16V)
* Signal to Noise (S/N) : 100dBA (referenced to rated power)
* Slew Factor : greater than 5
* Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged)
MAX Power (at 14.4V,EIAJ)
* Bridged 4 ohms : 400W x 1
* Per channel into 4 ohms : 140W x 2
RMS Power (at 12V,20Hz-20kHz)
* Bridged 4 ohms : 150W x 1 (0.3% THD)
* Per channel into 2 ohms : 75W x 2 (0.3% THD)
* Per channel into 4 ohms : 40W x 2 (0.08% THD)
RMS Power (at 14.4V,20Hz-20kHz)
* Bridged 4 ohms : 200W x 1 (0.3% THD)
* Per channel into 2 ohms : 100W x 2 (0.3% THD)
* Per channel into 4 ohms : 60W x 2 (0.08% THD)
Price : RM500
Alpine V12 EXPERT MADE IN JAPAN AMPLIFIER!!!!
Model : MRV-F505
Spec :
At 12V 20Hz-20kHz
4 x 50W @ 4 ohms (0.08% THD)
4 x 65W @ 2 ohms (0.3% THD)
2 x 130W @ 4 ohms bridge (0.3% THD)
At 14.4V 20Hz-20kHz
4 x 75W @ 4 ohms (0.08% THD)
4 x 100W @ 2 ohms (0.3% THD)
2 x 200W @ 4 ohms bridge (0.3% THD)
EIAJ MAXPOWER at 14.4V
160WX4CH
400WX2ch
SN : 105db
ORIGINAL MADE IN JAPAN!!!!
PRICE : RM1000
Complete Set
- Alpine DD Drive Midbass DDC-175B, 120watts 40RMS
- Alpine DD Drive Biodyna Dome Tweeter
- Alpine Passive Crossover Network 6564HX
Price : RM500
Alpine 6.5inch Speaker
Model : STE-163A
Spec : 120watts Peak, 30RMS, Impedance 4ohms
Price : RM100
Alpine 3way 6.5inch Speaker
Model : STE-174R
Spec : 150watts Max, Impedance 4ohms
Price : RM100
Alpine 12inch Woofer Made In Japan!!!
Model : SWF-304G
Spec : 600watts Max!! 200RMS
Price : RM350
Alpine Underseat Woofer Made In Japan!!!
Model : SBS-1395
Spec : 100watts Max, Buit In Amp
Price : RM250
Carrozzeria Satelite Made In JAPAN!! VERY RARE!!!! SOLD
Model : TS-RVX3
Spec : Max 100watts, Nominal 25watts, Impedance 4ohms
Price : RM400nett
Picture :
Kenwood 6.5inch Midbass Speaker SOLD
Model : KFC-SV1620
Spec : 160watts Max Music Power, Impedance 4ohms
Price : RM100
Rainbow 6.5inch High End Midbass Speaker SOLD
Model : W165SLX
Spec : 150watts Max power, Nominal 100watts, Frequency response 50-8000Hz, Impedance 4ohms
Price : RM100
Alpine DD Drive Midbass Speaker
Model : DDC-175B
Spec : 120watts Max, 40watts RMS
Price : RM100
Pioneer Carrozzeria 4inch 2way Speaker
Model : TS-E1070
Spec : 80watts Max, Nominal 25watts, Impedance 4ohms
Price : RM80
Alpine 3way Bass Reflex Speaker
Model : SBE1330
Spec : 100watts peak, 25watts RMS
Price : RM250
Carrozzeria 4way with Lights Made In Japan!!!
Model : TS-X450
Spec : 100watts Max, 25watts Nominal, Impedance 4ohms
Price : RM280
Carrozzeria 4way Made In Japan!!!
Model : TS-X480G
Spec : 120watts Max, Nominal 40watts, Impedance 4ohms
Price : RM280
Carrozzeria Green Bald Made In Japan SOLD
Model : TS-A7
Price : RM280
Carrozzeria Walnut 4way Green Bald!! RARE!!! SOLD
Model : TS-A90
Spec : 150watts Max, Nominal 50watts, Impedance 4ohms
Price : RM280
Carrozzeria Walnut 3way High End Spec!!!!
Model : TS-A100
Spec : 150watts Max, 50watts Nominal, 7X10 Woofer with Horn Tweeter
*High End Spec in Carrozeria Curtain Model
Price : RM300
Carrozzeria Japan 3way Green Bald SOLD
Model : TS-A70ZY
Spec : Max Music Power 120watts, Nominal 40watts
Price : RM280
Addzest Underseat Woofer Made In Japan!!
Model : PSW-160
Spec : 100watts Built in amp!!!
Price : RM250
Addzest 3way Bass Reflex Made IN Japan!!!
Model : SRB400
Spec : 120watts Peak, 13cm Injection Carbon COne Woofer, 6cm PEI Cone Mid Range 2cm Dome Tweeter
Price : RM250
Carrozzeria 4way Bass Reflex Made In JAPAN!!
Model : TS-X480
Price : RM280
Kenwood 4way Carbon!! Made In Japan!!
Model : KSC-770HP
Spec : 120watts Max, Impedance 4ohms
Price : RM280
Carrozzeria 3D FH-P88MD Made In Japan Double Din SOLD
Model : FH-P88MD
Specifications :
-Pioneer FH-P88MD In-Dash Double Din CD Player + MD player + DPS Receiver
-Unit has: MD player / CD player / Tuner / CD-R / CD-RW / MDLP / DHE / DSP / 7 pound EQ / 45W X 4 CH
-Great Visual Display. Moving Graphics and Stunning Equalizer
-2-Set of RCA (Front/Rear or Subwoofer)
-6-Mode Digital Sound Field Control (SFC) (Studio, Jazz Club, Hall, Dome, Stadium)
-Subwoofer LPF: 50/63/80/100/125/160/200Hz, Level -24 to +6dB
-Digital Processing provides 20-Bit accuracy for superior sound quality and detail
-Electronic 15-Band Digital Graphic Equalizer
-Other features include: Subwoofer level control, L.P.S. (listening postition selector), DHE (digital harmonic enhancer)& many display styles
-Mini Disc Long Play MDLP function
- Moterized face slides up and down to insert your CD's and MD's
Price : RM350
Picture :
Myvi Carbon Fibre Double Din Player Casing
Price : RM30
Kenwood CD/MP3 Player with remote Malaysia Spec SOLD
Model : KDC-MP4033
Price : RM200
Kenwood Stage 4inch Speaker
Model : KFC-RT100
Spec : 80watts Max, Impedance 4ohms
Price : RM80nett
Kenwood 4inch Black Speaker
Model : KFC-1080ie
Spec : 120watts MAx, Nominal 20watts, Impedance 4ohms
Price : RM80nett
Kenwood Pearl Mica 4inch Speaker
Model : KFC-C132
Spec : 90watts MAx, Impedance 4ohms
Price : RM80
Sony Xplod Tweeter Made In JAPAN!! With COndenser!! SOLD
Model : XS-H58
Spec : Max Power 150watts, Nominal 40watts, Impedance 4ohms
Price : RM80
Addzest 6.5inch Door Speaker
Model : SRT1621
Spec : 120watts Max,Impedance 4ohms
SUPERB SOUND CLARITY!!!
Price : RM100nett
Addzest ORIGINAL MADE IN JAPAN WITH COVER!!!
Model : SRF1380
Spec : 90watts Peak, OFC Voice Coil 189g, Strontium Magnet, 2cm Silk Diaphragm Tweeter
Price : RM100
Alpine CDA-9855J (Complete Set with FM Booster & iPod Adapter!!!!)
HIGH END HU!!!
Price : RM1200
Spec :
Spec :
* Built in 2way/3way Crossover
*Media Xpander to adjust sound that suit your listening style
* Subwoofer Level Control/Subwoofer Phase Selector
* 6channel Time Correction
* 5 band Parametric EQ
* 7band Graphics EQ
* GlideTouch touchstrip control replaces most faceplate buttons
* CD receiver with built-in amplifier (18 watts RMS/50 peak x 4 channels)
* Detachable, fold-down face with GlideTouch controls and BioLite display
* Plays audio CDs, CD-Rs and CD-RWs, plus discs burned with MP3 and WMA files
* Bass Engine Pro sound controls with iPersonalize setup options
* MediaXpander (restores clarity and detail to compressed or broadcast audio)
* MaxTune SQ tuner
* 12 FM/6 AM presets
* CD changer controls for Alpine Ai-NET changers only
* Compatible with Alpine's iPod interface adapter
* RCA Outputs: 3 Pair (front, rear, subwoofer)
* Preamp voltage: 4V
* CD frequency response: 5-20,000 Hz
* CD signal-to-noise ratio: 105 dB
* FM sensitivity: 9.3 dBf
Picture :
JVC CD/MP3 Player
Model : KD-G396
Price : RM200
Spec :
- CD Receiver with Front AUX
- MOS-FET 50W x 4 (20W RMS x 4)
- 24-bit DAC
- 3-Band iEQ
- MP3/WMA Compatible with ID3/WMA Tag (CD)
- HS Tuner
- Loudness Control
- 2.5V Line Output Level
- Line Output Terminals x 1 pair (Rear)
- Front AUX Input
Picture :
Carrozzeria 3way Speake System Green Bald SOLD!!!
Model : TS-A70II
Spec : 120watts MAx Music Power, 40watts Nominal, Impedance 4ohms
Price : RM250nett
Picture :
Alpine DD Linear Component SOLD!!!
- 1 set Alpine DD Linear 6.5inch Midbass Speaker
- 1 set Alpine DD Linear Dome Tweeter
- Alpine DD Drive Passive Crossover
Price : RM650
Picture :
Alpine DD Drive Biodyna Dome Tweeter Japan ONLY 1SET LEFT
Price : RM250
ORIGINAL MADE IN JAPAN!!! RARE ITEM
Picture :
Alpine DD Linear Satelite Speaker SOLD!!!
Counter Drive 2-way Coaxial Speaker
Spec : 150watts Peak, 30watts RMS, Impedance 4ohms
Picture :
Alpine 5inch 3way Speaker System
Model : STE-1231
Spec : 80watts peak, 20watts RMS
Price : RM100
Picture :
Kenwood AFC & Pearl Mica 6.5inch Speaker
Model : KFC-U1791
Type : 2way Speaker
Spec : Peak Power 150watts, Impedance 4ohms, Magnet 230g (8.1oz)
Price : RM100nett
Model : KFC-C162
Type : 2way 6.5inch Speaker
Spec : Peak 100watts, Impedance 4ohms, Magnet 190g(6.7oz)
Price : RM100nett
Picture :
For more JAPAN ICE item (speaker,tweeter,woofer) please visit my site Lazy Crazy Site!!!
Updates!!!New Item arrived!!!!
JAF Stickers 10, 20 and 30 years
Price : RM30 for 10years, RM30 for 20years and RM100 for 30years
Picture :
ANTERA VIP 17INCH RIM!!! ORIGINAL MADE IN ITALY SOLD
OFFSET : 40, 7.5JJ
PCD/HOLE : 114, 4HOLE
COMPLETE WITH TYRE!!!! TYRE JUST DONE APPROXIMATELY 10,OOOKM
Picture :
Alpine DD Drive Highest End Spec!!!!! ORIGINAL MADE IN JAPAN!!! SOLD
Model : DDC-F17C (This is the highest end spec for all DD Drive lineup)
Price : RM900nett (Direct Import from Japan, not from halfcut!!!)
Complete Set : 1set Midbass, 1set Biodyna Dome Tweeter and 1 set Passive Crossover!!
Picture :
Alpine 2way 5inch Speaker
Type : 2way Speaker
Spec : 80watts peak, 20wats RMS
Price : RM80nett
Picture :
Alpine Passive Crossover Japan!!!!
Price : RM250
Adjustable Desible for Tweeter!!!
Picture :
Alpine DD Linear 6.5inch from JAPAN!!! SOLD!!!
Model : DLS-178X
Spec : 160watts Max, 40watts RMS, Impedance 4ohms
Price : RM120nett
Picture :
Alpine DD Drive 12inch Woofer ORIGINAL MADE IN JAPAN!!! SOLD!!!
Model : DDW-F30A
Spec : 600watts Max, 200watts RMS, Impedance 4ohms
This model is ORIGINAL MADE IN JAPAN!!!
Produce and sold in Japan only!!!
Only 4 unit of woofer left. This is the highest end model of Alpine before DD Linear starts to launch on 2004
Price : RM800 per woofer
Picture :
Alpine Bass RS 6inch Woofer
Model : Bass RS 6inch
Spec : 150watts, Impedance 4ohms
Price : RM40
Picture :
Alpine Tune By Luxman!! ORGINAL MADE IN JAPAN!!! SOLD!!!
Price : RM350nett
Picture :
Alpine RCA Cable MADE IN JAPAN!!!! VERY RARE!!! SOLD
Price : RM150nett
Used to connect to amp or woofer
Alpine DD Linear Tweeter SOLD
Price : RM180
Picture :
Alpine 12 inch Woofer MADE IN JAPAN SOLD!!!
Picture :
Alpine Dome Tweeter SOLD!!!
Model : DDC-175B
Price : RM80nett
Picture :
Alpine Underseat Woofer SOLD!!!
Price : RM350nett
Picture :
Kenwood Carbon Fiber 4way Speaker JAPAN!!!
Model : KSC-770HP
Spec : 120watts Max, Ipedance 4ohms
Price : RM280nett
Picture :
Kenwood Mira 3way Speaker with Lights!!! MADE IN JAPAN!!!
Price : RM150
Picture :
Model : KFC-S1600
Spec : Max 120watts, Impedance 4ohms, Magnet 230g
Price : RM100
Picture :
Model : KFC-SV1610
Spec : 150watts Max, Impedance 4ohms, Neodymium Magnet
Price : RM100nett
Picture :
Kenwood 6.5inch Carbon Made In Japan SOLD
Model : KFC-U160
Spec : Peak Power 120watts, Impedance 4ohms
Price : RM100
Picture :
Kenwood 6.5inch 2way Speaker
Model : KFC-C165
Spec : Peak Power 80watts, Impedance 4ohms
Price : RM100
Picture :
Kenwood Oval 4Xk 2way Coaxial Speaker
Model: KFC-U5792
Spec : 120watts, Impedance 4ohms
Price : RM70
Picture :
Kenwood 5inch Speaker with Cover
Model : KFC-J1376
Spec : 130watts Mx Music Power, Impedance 4ohms
Price : RM100
Picture :
Kenwood Tweeter ( 3 set left )
Price : RM80 per set
SOft and clear clarity Tweeter!!!!
Picture :
Kenwood AFC 2way 6.5inch Speaker
Model : KFC-U1691
Spec : Peak power 120watts, Impedance 4ohms
Price : RM100
Picture :
Kenwood 10inch Woofer!!!!
Spec : 360watts Peak Power, Impedance 4ohms
Price : RM150
Very Powerful Woofer!!!
Picture :
Kenwood 2way 4X6 Speaker System
Model : KFC-U4691
Spec : 90watts Max, Impedance 4ohms
Price : RM70nett
Picture :
Kenwood 3way Speaker Japan with Lights!!! SOLD
Model : KSC-505
Spec : Max Music 130watts
Price : RM280nett
Picture :
Model : KFC-RS17
Spec : 140watts Peak Power, 35watts Nominal, Impedance 4ohms
Price : RM100
Picture :
Addzest Midbass 6.5inch Speaker SOLD
Model : SRT1752S
Spec : Max Music Power 200watts!! 45watts RMS, Impedance 4ohms
Price : RM100
Picture :
Clarion Addzest 3way Speaker
Type " 3way Speaker
Spec : 130watts peak, Impedance 4ohms, 2.5cm PEI Balance DriveMid-Range, 0.8cm Piezo Dome Tweeter
Price : RM100nett
Picture :
Clarion Addzest Chrome Tweeter!! RARE!!!
Type : Silk DOme Tweeter
Price : RM100nett
Picture :
Addzest 2way 6.5inch Speaker
Model : SRT1730
Spec : Max Music 160watts, Nominal power 45watts, Impedance 4ohms
Price : RM100nett
Picture :
Pioneer Carrozzeria Japan Tweeter!!!! SOLD
Model : DS-459A
Spec : Dome Tweeter
Price : RM80nett
Picture :
Carrozzeria Carbon 6.5inch Made In Japan
Model : TS-F1700
Spec : Max Music Power 120watts, 30watts RMS, Impedance 4ohms
Price : RM100
Picture :
Carrozzeria Carbon Japan with Condenser SOLD
Model : TS - J120A
Spec : 110watts max, 25watts Nominal, Impedance 4ohms
Price : RM100
Picture :
Pioneer 5inch 3way Speaker
Model : TS-E1395
Spec : 160watts Max, 35watts Nominal, Impedance 4ohms
Price : RM100 nett
Picture :
Carrozzeria Oval 2way Speaker
Superb Bass and Clarity!!!
Price : RM70
Picture :
Pioneer Japan 4X6 Coaxial 3way Speaker
Model : TS-4688
Spec : 80watts max, Nominal 20watts, Impedance 4ohms
Price : RM70nett
Picture :
Carrozzeria Tube Woofer Original Made In Japan SOLD
Spec : 200watts Max
Price : RM500nett
DARE TO BE DIFFERENT?
Picture :
Carrozzeria Carbon Fiber 4inch MADE IN jAPAN!!! SOLD!!!
Price : RM80
Picture :
Carrozzeria 8inch Woofer SOLD!!!
Max Music Power 180watts
Price : RM150nett
Picture :
Eclipse Tweeter!!!!
Superb Clarity!!!!
Price : RM80nett
Picture :
Eclipse 4inch Dashboard Speaker SOLD!!!
Model : E1017GT
Spec : 80watts Max, 25watts Nominal, Impedance 4ohms
Price : RM80 nett
*Superb sound clarity. Suitable for SQ
Picture :
Fusion Japan Tweeter!!!
Price : RM80nett
JVC RC Cable Made in JAPAN!!!! SOLD!!!
Price : RM100
Picture :
Diatone 6.5inch Speaker System
Type : Coaxial 2way Speaker
Spec : 140watts max, Nominal 35watts, Impedance 4ohms
Price : RM100nett
Picture :
BM Boschmann 5inch 3way Bass Speaker with Cover
Model : B-503KS
Spec : 140watts Max, Impedance 4ohms
Price : RM100nett
Picture :
BM Boschmann 2way Passive Crossover
Price : RM100
Picture :
Package 1
Price : RM1600 nett
Package 2
Price : RM2400 nett
Package 3
Item :
Price : RM3000nett
Package 4
Item :
Price : RM4000nett
Package 5
Item :
Price : RM4500nett
Package 6
Price : RM5000nett
Specification
Alpine PXA-H701
Helix Baby Cap
- 33,000 uF
- Umax = 30V
- Model : DDC-F17C
- Impedance 4ohms
Model : DDW-F30A
Weight : 5.9Kg
- Neodymium Magnet
- Rubber Sorround
PXA-H701 + RUX-C701
Price : RM1200
Picture :
Model : TS-C016A
Price : RM100
Model : TS-C160AII
Price : RM100
Model : STE-102J
Price : RM80
Model : STE-123A
Price : RM80
Model : STE-100C
Price : RM80
Model : SWS-1042D
Spec :
Price : RM500
Spec :
# Graphic equalizer
# MediaXpander
Price : RM1400
Model : MRV-T407
Spec :
# Bass EQ Circuit
# Bass Engine Ready
# MultiMode
# Phase Selector
# STAR Circuitry
# Subsonic Filter
Price : RM500
Model : MRV-F505
Spec :
At 12V 20Hz-20kHz
At 14.4V 20Hz-20kHz
160WX4CH
400WX2ch
SN : 105db
PRICE : RM1000
Complete Set
Price : RM500
Model : STE-163A
Price : RM100
Model : STE-174R
Price : RM100
Model : SWF-304G
Price : RM350
Model : SBS-1395
Price : RM250
Model : TS-RVX3
Price : RM400nett
Picture :
Model : KFC-SV1620
Price : RM100
Model : W165SLX
Price : RM100
Model : DDC-175B
Price : RM100
Model : TS-E1070
Price : RM80
Model : SBE1330
Price : RM250
Model : TS-X450
Price : RM280
Model : TS-X480G
Price : RM280
Model : TS-A7
Price : RM280
Model : TS-A90
Price : RM280
Model : TS-A100
Price : RM300
Model : TS-A70ZY
Price : RM280
Model : PSW-160
Price : RM250
Model : SRB400
Price : RM250
Model : TS-X480
Price : RM280
Model : KSC-770HP
Price : RM280
Model : FH-P88MD
Specifications :
Price : RM350
Picture :
Price : RM30
Model : KDC-MP4033
Price : RM200
Model : KFC-RT100
Price : RM80nett
Model : KFC-1080ie
Price : RM80nett
Model : KFC-C132
Price : RM80
Model : XS-H58
Price : RM80
Model : SRT1621
Price : RM100nett
Model : SRF1380
Price : RM100
HIGH END HU!!!
Price : RM1200
Spec :
Spec :
* 7band Graphics EQ
* MaxTune SQ tuner
Picture :
JVC CD/MP3 Player
Model : KD-G396
Price : RM200
Spec :
- 24-bit DAC
- 3-Band iEQ
- HS Tuner
- Loudness Control
- Front AUX Input
Picture :
Model : TS-A70II
Price : RM250nett
Picture :
Price : RM650
Picture :
Price : RM250
Picture :
Picture :
Model : STE-1231
Price : RM100
Picture :
Model : KFC-U1791
Type : 2way Speaker
Price : RM100nett
Model : KFC-C162
Price : RM100nett
Picture :
Picture :
OFFSET : 40, 7.5JJ
Picture :
Picture :
Type : 2way Speaker
Price : RM80nett
Picture :
Price : RM250
Picture :
Model : DLS-178X
Price : RM120nett
Picture :
Model : DDW-F30A
Picture :
Price : RM40
Picture :
Price : RM350nett
Picture :
Price : RM150nett
Price : RM180
Picture :
Picture :
Model : DDC-175B
Price : RM80nett
Picture :
Price : RM350nett
Picture :
Model : KSC-770HP
Price : RM280nett
Picture :
Price : RM150
Picture :
Model : KFC-S1600
Price : RM100
Picture :
Model : KFC-SV1610
Price : RM100nett
Picture :
Model : KFC-U160
Price : RM100
Picture :
Model : KFC-C165
Price : RM100
Picture :
Model: KFC-U5792
Price : RM70
Picture :
Model : KFC-J1376
Price : RM100
Picture :
Picture :
Model : KFC-U1691
Price : RM100
Picture :
Price : RM150
Picture :
Model : KFC-U4691
Price : RM70nett
Picture :
Model : KSC-505
Price : RM280nett
Picture :
Model : KFC-RS17
Price : RM100
Picture :
Model : SRT1752S
Price : RM100
Picture :
Type " 3way Speaker
Price : RM100nett
Picture :
Price : RM100nett
Picture :
Model : SRT1730
Price : RM100nett
Picture :
Model : DS-459A
Spec : Dome Tweeter
Price : RM80nett
Picture :
Model : TS-F1700
Price : RM100
Picture :
Model : TS - J120A
Price : RM100
Picture :
Model : TS-E1395
Price : RM100 nett
Picture :
Price : RM70
Picture :
Model : TS-4688
Price : RM70nett
Picture :
Spec : 200watts Max
Price : RM500nett
Picture :
Price : RM80
Picture :
Price : RM150nett
Picture :
Eclipse Tweeter!!!!
Superb Clarity!!!!
Price : RM80nett
Picture :
Model : E1017GT
Price : RM80 nett
Picture :
Price : RM80nett
Price : RM100
Picture :
Price : RM100nett
Picture :
Model : B-503KS
Price : RM100nett
Picture :
Price : RM100
Picture :
