Car Engine Jerking
edwin_lcw
1,242
Setapak
Hi all,
Mind you guys sharing if your perdana did face any problem like mine ?
The engine jerk when going uphill or when temperature is hot like afternoon.
Previously I suspect the problem is from my spark cables and problem did settle after changing one set of original cables(so called lah), one set of cables from half cut and at last one set dunno what brand but its expensive around 300++
but after a year problem comes back again.
I somehow got this feeling its not the cables that makes this problem.
Any advise ?
edwin_lcw
1,242
Setapak
sorry but they say no problem ...
headache la ... any recommended foremen ?
edwin_lcw
1,242
Setapak
blue i dunno what brand ....
now its black wit red box .... 200++
edwin_lcw
1,242
Setapak
new updates ... yes peter your right !!!
after checking with the V-sixers in Australia found out actually the spark plugs seal that blocks the engine oil from wetting the plugs worn out hence the plug is in total disaster
dunno how it affects but it really causes the plug to misfire and also the cable to die off too ....
now have to change all 6 seals and plugs ... no problem so far
Nov 19, 2012
Klang
Hi Team Memberz.
Actually my V6 also having the same issue jerking
When up on the hills. I would like to noe what is the
problem & how to get rid of it?
Need your assistance guys. Tq
Hi sifus,
Need some advice here.
Few months back, my car a Proton Wira 1.6 has encountered swaying problem.
At times the steering would pull to the left and at times will be to the right even on a straight flat road (Kesas, NPE or Federal highway).
Even on straight road the steering always has to be corrected.
I've changed rims, 4pcs brand new tyres (PS3), all rear bushing (including trailing arm is brand new), alignment but things became worse!
Front lower arm (driver's side)...
