Item 1
Altec Lansing 6.5 inch Component
-Normal Impedance 40 Ohms
-Maximum Power 400w
-Nominal POwer 200w
-Sensitivity 91dB
-Frequency Response 35Hz-22KHz
=Selling Price RM150 (1Set) *Less 30% = Rm 105
Item 2
Sefiro Tweeter
-92dB S.P.L.
=Selling Price RM25 (1pair)
Item 3
XXX 12 inch Woofer
-1.5 inch 4-Layers BASV
-40 OZ Magnet
-Frequency 22Hz-1.4KHz
-Impedance 4ohms
-Max Power 1500w
-Sensitivity (1m/1w) 92dB
=Selling Price RM120 (1pc) *Less 30% = Rm 84
Item 4
Audio Focus 1Farad Cap
-1.0F
-20V dc
=Selling Price RM300 (1pc) *Less 30% = Rm 210
Item 5
Audio Focus Pre-amp
-Power Source 10-14.4V dc
-Input Current 0.5Amps Max
-Output Level 0.5Amps Max
-Distortion 0.01% THP at 1v Output Level
-Frequency Response 10Hz-30KHz + 3dB
-S/N Ratio >90dB (A)
-Sparation >60dB
-Bass Adjust +10dB
-Mid bass Adjust +10dB
-Mis Adjust +10dB
-Treble Adjust +10dB
-Sub Bass 43Hz & 60Hz
=Selling Price RM100 (1pc) *Less 30% = Rm 70
Item 6
Pyle Pre-amp
-Sub Bass Equalizer Frequency 35Hz
-Low Equalizer Frequency 200Hz
-Mid Equalizer Frequency 1KHz
-High Equalizer Frequency 20KHz
-S/N Ratio 80dB REF 1v Input
-Frequency Response 20Hz-35KHz +1dB
-Max Output Voltage 7v RMS
-T.H.D. 0.05%
-Input Impedance 20k Ohms
-Stereo Seperation -55dB/1KHz
-Subwoofer Boost 0-12dB
-Subwoofer Frequency Range 40Hz-400Hz
-Operation Voltage 11-15V dc Negative Ground
=Selling Price RM180 (1pc) *Less 30% = Rm 126
Item 7
Tarantula 2channel Amp
-RMS @ 4ohms 100x2
-RMS @ 2ohms 200x2
-RMS Bridged @ 4ohms 400x1
-T.H.D. <0.02%
-Frequency Response (Hz) 10-50K
-Signal To Noise Ratio >115dB
-Damping Factor >500
-Input Sensitivity 0.15-12.0v
-Crossover Slope 12dB
-Crossover Frequency (Hz) 50-5k
Item 8
E-Zone 2channel Amp
-Supply Voltage 11-15V dc
-RMS @ 4ohms 80x2
-RMS @ 2ohms 100x2
-RMS Bridged @ 4ohms 140x1
-Frequency Response 20Hz-36KHz (-1dB)
-Channels Seperation 50dB (+A)
-Signal To Noise Ratio 90dB (+A)
-Input Impedance 22k ohm
-Input Sensitivity 200mv-2v
-T.H.D. <0.05%
-HI Pass Frequency 50Hz-250Hz
-Low Pass Frequency 50Hz-250Hz
-Bass Boost 12dB
Item 9
E-Zone 4channel Amp
-RMS @ 4ohms 60x2
-RMS @ 2ohms 80x2
-RMS Bridged @ 4ohms 120x1
-T.H.D. <0.05%
-Bass Boost 12dB
=Selling Price RM280 (1pc) *Less 30% = Rm 196
Item 10
Takara Monoblock
-Output Max 2000w (2ohm)
-Frequence Response 10Hz-250hz
-Input Sensitivity Low 0.1-10v Impedance 15k ohm
-Signal Ratio >100dB
-Speaker Impedance 2-8ohm
-Subwoofer Frequency 15Hz-50Hz Adjustable
=Selling Price RM450 (1pc) *Less 30% = Rm 315
All these products are clearance price. All prices are nett. If u get 2 items and above u will
get 1 set of Sefiro Tweeter free! All items comes with box and manual. All items are brand new and
comes with 1 year warranty from distributor. Any item not working, 1 to 1 exchange. Refer to
pictures on items.
For more info contact 012-3377736
Location Subang/Sunway
Cheers.
*Updated with new price
-Maximum Power 400w
-Nominal POwer 200w
-Sensitivity 91dB
Item 2
Sefiro Tweeter
-92dB S.P.L.
Item 3
XXX 12 inch Woofer
-40 OZ Magnet
-Impedance 4ohms
-Max Power 1500w
Item 4
-1.0F
-20V dc
Item 5
Audio Focus Pre-amp
-Sparation >60dB
-Bass Adjust +10dB
-Mis Adjust +10dB
Item 6
Pyle Pre-amp
-T.H.D. 0.05%
Item 7
-RMS @ 4ohms 100x2
-RMS @ 2ohms 200x2
-T.H.D. <0.02%
Item 8
E-Zone 2channel Amp
-RMS @ 4ohms 80x2
-RMS @ 2ohms 100x2
-T.H.D. <0.05%
-Bass Boost 12dB
Item 9
E-Zone 4channel Amp
-RMS @ 4ohms 60x2
-RMS @ 2ohms 80x2
-T.H.D. <0.05%
-Bass Boost 12dB
Item 10
Takara Monoblock
pictures on items.
Cheers.
