Can I ask that can we use drive shaft grease for wheel bearing?are they compatible?
anyone used it before without any problem such as bearing worn out faster
RWD can cause the car to have more oversteer and AWD make the car to have more understeer when coming to corners
Even Nissan GTR R33 & R34 in Japan GT is modified to RWD with wider tire in the front at is 330mm while car like Enzo FXX front tire is only 255mm or 245mm
But RWD are more likely to spin in corner if throttle is applied, will be harder to turn a AWD as will cause understeer
The reason AWD doesn't spin out that easily is because some percentage of power is transferred to...
