can vios 07 change the sport air filter??
fr0z3nwei
21
my car is vios 07..i wanna to change a sport air filter..but the the ori air filter got a sorket..so im not sure can it change or not..
the air filter that i wan to change is in the photo...
can the sensor take out from the ori intake pipping??
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
You can change to sport filter as long your sensor is put back to the intake piping. The socket is for your MAF sensor...
RWD can cause the car to have more oversteer and AWD make the car to have more understeer when coming to corners
Even Nissan GTR R33 & R34 in Japan GT is modified to RWD with wider tire in the front at is 330mm while car like Enzo FXX front tire is only 255mm or 245mm
But RWD are more likely to spin in corner if throttle is applied, will be harder to turn a AWD as will cause understeer
The reason AWD doesn't spin out that easily is because some percentage of power is transferred to...
