- Joined
- Aug 23, 2004
- Messages
- 70
- Points
- 3,006
I'm using a 3S-GTE and had just transplanted this engine on my MR2.
At 0.5bar which is the stock boost, everything was going fine n smooth. Redline is at 7000rpm.
After increasing the boost to 0.7 the rpm seems to stall for awhile at 5000rpm then continue as per normal. A wierd GRRR sound appears and the boost drops by 0.2 when this happens, b4 continuing to speed on to 7000rpm as per normal. After explaining this to my friend he said that its mis-firing. wat does this mean? and how do i fix it if? If its not misfiring, then wat is the problem?
At first it only happened on the 3rd,4th and 5th gears. After some time now, its also happening on 2nd gear. In other words, getting worse... and more frequent.
I just had my car for less than a year so i'm new to turbocharged engines, its technical functions...etc.
Really need some help on this. Thx
