BLOX TURBO OIL INLET
This kit is flow regulated to prevent bearing cartridge oil seals from blowing out at high oil pressures. The regulator hole is designed with a 1.62mm opening and it can be easily re-drilled with larger hole to increase the oil flow to the turbocharger if necessary. When re-drilling a larger hole, do not exceed 5mm( 7/32 ).
(Universal) complete oil line kit with braided turbo oil drain pipe.
WILL FIT Turbine of: T3, T3T4, T4, T70, T66 , T04B, TO4E, IHI RHC6, T61, T60, GT45, K27 and almost all the turbo chargers (OIL COOLED TURBINE ONLY)
Package Includes:
- Oil restrictor (special designed inlet adapter limits oil flow, effectively prevent blown oil seal caused by excessive oil pressure)
- 1/8" Adapter NPT male fitting that goes to the block and one- 4AN male fitting built on flange. (Made out of Grade 7075 Alum).
- 36" long stainless steel braided line with 3/8 diameter
- comes with gasket, screws/washer
- 17" braided oil drain line
- Heavy duty oil drain adaptors and fittings
- Selling Price RM 150
Package Includes:
