receive info from friend.If Ipoh, look for bro. Renesis, If KL then look for me.....hhahhahahha
next trip, this monday. go north Baling, kedah.
call tauke, have jdm choices.
All trip is during offday.
Stagger size cannot rotate tyres.....:hmmmm:I used to buy my P1 with rare size
114.3 x 4, 8jj front, 9jj rear in temerloh, Pahang.
the seller's name is mamat temerloh, quite famous last time, now not sure.
rims are cheaper than those sold in halfcuts.
Your offday all on weekdays. Weekend also you work?receive info from friend.
Actually I don't know why danz is using larger size for his rear tyres considering his twin turbo is FWD.Stagger size cannot rotate tyres.....:hmmmm:
Gaya mah! Wider tyres in the rear......Your offday all on weekdays. Weekend also you work?
He got twin turbo, can afford to use heavier wheels at rear. If normal FWD cars, FC sure affected badly.Gaya mah! Wider tyres in the rear......
Because the word "twin" means more power......lolHe got twin turbo, can afford to use heavier wheels at rear. If normal FWD cars, FC sure affected badly.
Looking at those, doesn't seem cheaper.seems to be still active?
http://www.mudah.my/mamat-temerloh
Not really what. For high powered engines like those heavily modded RB26DETT or 2JZ-GTE, they tend to convert to single large turbo instead of retaining the original twin turbo setup.Because the word "twin" means more power......lol
work 4 days off 2 days. No fixed off day.Your offday all on weekdays. Weekend also you work?
yes, mine is sequential twin turbo, both small turbo, one big one small is parallel turbo, if not mistaken. like fd3sNot really what. For high powered engines like those heavily modded RB26DETT or 2JZ-GTE, they tend to convert to single large turbo instead of retaining the original twin turbo setup.
If I am not mistaken, 6A12TT is using a sequential twin turbo setup. One big, one small turbo.
That is the thing, twin not necessary more power. The way you word it like twin is so powerful....hhahahhahaNot really what. For high powered engines like those heavily modded RB26DETT or 2JZ-GTE, they tend to convert to single large turbo instead of retaining the original twin turbo setup.
extra one day is split into OT. ,Missing one day?????
