Battery Or Starter Problem
huszua
262
6
Dear all,
Need some advice,
Within this 1 months, my car always susah to start on morning.
The symptoms like battery weak.
Last Saturday, i bought new battery and changed.
Yesterday morning, when i want to start, its still the same.
The symptoms still like battery weak.
Is it the battery problem or starter?
Thanks
huszua
262
6
when u start yr car, remove the + & - terminal, if yr engine still running, alternator ok, if engine mati, alternator kong.
Will try this today.
But i think, the alternator is OK.
If there is any possibility the Starter problem?
levin818
1,260
321
3,183
Shah Alam
"symptoms like battery weak..."
Do you mean the cranking sound is like mati tak mati?
Or the crank sound is strong but take longer time to start?
Both due to diff problem le.
SomeGuy_sg
159
6
5,018
It really sounds like an alternator problem or some accessories are leeching power off the battery when the car is turned off.
Start up the car and use a multimeter to check the batter status/power. The alternator should charge the battery when it falls past a certain limit or some car just keep charging the battery. Charging should be around 12.7V to around 13.7V. You might want to check with your workshop manual or dealer for the actually specs.
huszua
262
6
The sound is like mati tak mati....
Ekkk..Ekk..ekkkk... then start...
huszua
262
6
bro, sounds like ur starter. Happened to me recently!
Thanks for the feedback.
Will change the starter and update tomorrow.
Just bought the starter at kedai potong.
Cost me RM130.
How much the foreman upah meh?
Thanks again
huszua
262
6
Problem settle
It was the starter problem
Changed and everything back to normal.
Thanks for all the feedback..
17 May 2013
A car of my friend's was stolen at Taman Bahagia, Petaling Jaya between the time 1.30pm - 10.00pm. It was parked at a housing area in front of a padang and no one would thought that it could be stolen there. Now, he has lodged a police report in BALAI POLIS SS2. Hopefully, the police could locate where the car is.
Anyone who sees a white viva elite, car number plate BKN 5608. Please do let the police know or call 017-2064126 Kevin Liew (Owner) !
Be very careful and...
